By buying this product you get 25 loyalty points
This 100% digital pack including the best streamer and the best FDA amplifier (Full Digital Amplifier) will allow you to get a complete system (excluding speakers).
Supporting all advanced streaming technologies and connectable via Ethernet or wifi to the Internet or your local network, IEast will allow you to access via its application to the best online music services.
The FX-D802 unanimously praised by the audiophile community will decode and amplify the digital signal delivered by the streamer to offer you a dynamic, realistic and detailed rendering.
Ce bundle complete (all the necessary is delivered including the cable of optical link) to the very small footprint will allow you to dispose of the best of the dematerialized at a very attractive price.
The FX-Audio:
A complete STA326 Class D amplifier with remote control, the FX-AUDIO D802 incorporates a 24bit 192kHz analog digital converter with an AKM AK4113 S / PDIF interface and a VIA VT1630A Audio / DSP interface.
This amplifier has the characteristic of being a "Full Digital", ie the S / PDIF signal is converted into I2S by the AK4113 and then directly amplified by the STA326.
It has three digital inputs (USB, S / PDIF coxial and Toslink optics).
Its OLED display displays in real time the source used as well as the sampling rate of the audio file being played.
This all-in-one amplifier is also equipped with a digital equalizer with many functions (bass, treble, etc ...) adjustable directly from the remote control.
hewill prove to be the ideal companion for any digital source.
Hisergonomics and compactness are notable advantages, plus its versatility.
Features:br>
[Img-13859-left-thickbox_default]<br>
[Img-13861-left-thickbox_default]
[Img-13862-left-thickbox_default]
The IEast M30:
This compact WiFi audio streamer / receiver allows you to listen to music on your HiFi system directly from your Smartphone, tablet, computer, or other DLNA / AirPlay / UPnP compatible source.
The iEast receiver has WPS technology, allowing you to connect to the WiFi network in a simple, fast and secure way. The WPS button on the case allows you to access this option. You can also connect it via its RJ45 Ethernet port, free to choose according to your preferences.
With a 3.5mm Stereo Jack and a Toslink Optical Output, you can easily connect it to your HiFi or audio amplifier to listen to music up to 24 bit / 192kHz .
This product also allows playback of audio files via its USB-A port , up to 1 TB.
Equipped with audiophile components such as an ESS ES9023 Saber DAC , it will fit perfectly with your HiFi system.
The remote controlc allows you to select the song, manage the volume, and play or pause music when the receiver is in the file player (USB) mode. It also allows you to turn the iEast off and on, as well as select the previously configured quick access list (see operating instructions).
An iEast Play app is available on Android and iOS. It allows you to access music stored on your Smartphone, on your NAS (Synology, QNAP, etc.) ... in short, centralization of your music libraries on a single dedicated application and to easily manage the multiroom.
The Streamer iEast is compatible with all these music services:
Features:
Strong points :
Specifications:
Connectors:
Packaging:
[Img-17646-left-thickbox_default]
