NEOSET-165 2-Way Exploded Kit (Pair)
Reference : 1301
219,00 €tax incl.
182,50 € tax excl.
High Tech system for car HiFi, 3 Ω, 200 WMAX, 100WRMS
The NEOSET Compo systems CARPOWER combine a  NEOKICK bass speaker with DT-284 tweeter speaker specially developped and NEOSET filter for a set with an amazing quality of restitution to these dimensions and price range.
These systems have almost everything: extremely small dimensions, complete neodymium magnet, a well-balanced sound behavior thanks to the synthetic laminate membrane low-medium and high speaker with silk membrane. A very precise filter allow for clear and precise sound restitution. The level behavior is well above average. With the 165 system, you can work directly above the high-power subwoofers or in addition to powerful bass, you can also design the set in fullrange. (See the technical data of the NEOKICK-165 and the DT284, the different power and impedance values ​​are due to the combination with the NEOSET filter). Supplied with protective grilles
Impedance3 Ω
Bandwidthf3-20000 Hz
Frequency2100Hz
Allowable load200 WMAX
Sound pressure Average (1W / 1m)87 dB
Dimensionsø 166 mm x 60 mm
Weight1.5kg
componentsNEOKICK-165
DT-284
