CARPOWER Subwoofer SONIC-10MK2 25cm
Reference : 1527
218,50 €tax incl.
182,08 € tax excl.
Clean, very deep, very very powerful and stable even for the highest levels: this is how it is to react a serious Hi-Fi embedded top level in smaller enclosures. The new SONIC bass meets these requirements perfectly, and at a price that can only be realized by CARPOWER for these High Tech woofers.
Top Class Hi-Fi Subwoofer, 2x500 W MAX, 2x300WRMS, 2x2 Ω
10 "high-powered double-coil bass speaker, solid steel molded bowl, the carbon fiber membrane is surrounded by an exclusive long-travel rubber suspension and even the 25 cm SONIC is controlled by the same system The linear excursion is +/- 25 mm at full efficiency and allows an absolutely breathtaking bass reproduction.The output is certainly not extraordinarily high but you can reach levels deafening, combined with a very high power rating. The necessary speakers with only 15 liters in a cabinet cabinet or 25-35 liters in bass reflex are so small that the SONIC-10 can sometimes only be gigantic dimensions on the outside.
Impedance (Z) 2x2 Ω
Resonance frequency (fs) 31 Hz
Maximum bandwidthf3-300 Hz
Maximum power2x500WMAX
Rated power (P)2x300WRMS
Average sound pressure (1 W / 1 m)84 dB
Compliance susp. (Cms)0.14 mm / N
Moving mass (Mms)188 g
Mechanical overvoltage. (Qms) 8.25
Electrical overvoltage (Qes) 0.53
Fact. total surge (Qts)0.49
Volume equ. (VAS) 24 l
DC resistance. (Re) 2x1.9 Ω / 1x3.8 Ω
Force factor (BxL)17Tm
Inductance coil (The)2x0.7 mH / 1x2.8 mH
Coil diameter 75 mm
Coil holderKAPTON
Linear excursion (X MAX)± 25 mm
Transmitting surface (Sd) 346cm2
Magnet Weight180 oz
Weight14.5 kg
Speaker TypeSubwoofer
Loudspeaker diameter (mm)250.0
