DAYTON AUDIO DCS205-4 Classic Speaker Driver Subwoofer 150W 4 Ohm 89dB 30Hz - 200Hz Ø20cm
Subwoofer speaker for repair / construction / prototyping. Diameter 20,3 cm. RMS 150W
Reference : 12688
89,00 €tax incl.
74,17 € tax excl.
This product is temporarily unavailable.
Dayton Audio DCS205-4 Classic Subwoofer 4 Ohms
Speaker Type Subwoofer Classic series
DCS205-4 Classic subwoofer front view
Deep and well defined bass
Top coil speaker DCS205 4
With a generous frequency response due to its size, this speaker is a versatile choice that will be able to accommodate all kinds of uses. Audiophile system to home cinema, it will serve equally well to fix a speaker to make prototyping and mount a speaker on its own. Its relatively low weight in its class also makes it a perfect choice for the portable systems requiring showcase infrabasses.
This speaker has a ventilated motor, which allows you to enjoy an interesting sensitivity while limiting the natural distortion. Its membrane Kevlar / Paper allows it to remain accurate while riding in powers of 150W RMS.
Mounted with another high-woofer (woofer) and two tweeters there will be the basis for advantageous arrangements of a view / performance space.
TypeSubwoofer Speakers
RMS power150 Watts
Max power300 Watts
Impedance4 Ohms
Frequency response30-200 Hz
Sensitivity88.6 dB 2.83V / 1m
reel diameter38.3 mm
resonant frequency32.3 Hz
DC resistance (Re)3.9 Ohms
Inductance (Le)1.78 mH
Mechanical quality coefficient (Qms)6.28
Coefficient of Power Quality (Qes)0.4
total quality factor (Qts)0.37
Moving mass + air load (Mms)57.7g
Compliance of the suspension (Cms)0.42 mm / N
emitting surface (Sd)213.8 cm²
maximum linear excursion8.8 mm
total diameter20.32 mm
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume5.38 Litres
Sealed F378 Hz
Vented Volume13.59 Litres
Vented F348 Hz
Speaker Power (W RMS)150.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)200.0
Diaphragm typePaper
Diaphragm typeCarbon kevlar
Efficiency / Sensitivity (dB)89.0
Max Linear Excursion (Xmax) (mm)8.8
Lowest frequency (Hz)30
Highest frequency (Hz)200
Parfait
Correspond à ma demande, produit arrivé rapidement et monté dans mon sub en remplacement d'un ancien et la différence est enorme !!
This review has been posted for DAYTON AUDIO DCS205-4 Classic Speaker Driver Subwoofer 150W 4 Ohm 89dB 30Hz - 200Hz Ø20cm
