DAYTON AUDIO UM12-22 Ultimax DVC Speaker Driver Subwoofer 600W 2x2 Ohm 87dB 20Hz - 1000Hz Ø30cm
Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Discover the best price-to-market ratio!
Strengths:
  • Power rating 600 W on 4 ohm (2 coils)
  • Resonance frequency 26.5Hz.
  • As efficient in Hifi as Home theater use
  • Nomex cone low colouring
  • Double spider
By buying this product you get 31 loyalty points
Reference : 12583
319,00 €tax incl.
265,83 € tax excl.
Ultimax
Subwoofer DVC 4Ω ⌀30cm 600W RMS
This exceptional subwoofer with ultra-stiff, ventilated chassis has powerful ceramic magnets. Its high rigidity Nomex/glass fiber cone in honeycomb structure produces powerful bass, defined without harmful coloring. Thanks to its 2+2 coils system its long linear elongation with double spider this subwoofer is able to reach frequencies of 26.5Hz.
Alignment possible according to pure volume and load:
  • Volume closed - F3 : 34 Hz / 80L
  • Volume vented - F3 : 17 Hz / 140L
Technical specifications
loudspeakers type :Subwoofer
Nominal diameter30cm (12")
Menbrane materialNomex galss fiber
Magnet type ferrit Ceramic
Voice coil materialCopper
Total diameter chassis297mm
Depth191mm
PowerRMS : 600W sur 4 ohm  2+2 bobines
MAX : 1200W
Impedance nominal charge
Sensibility86.7dB @ 2.83V/1m
Frenquency response20Hz -1000Hz
DC resistance (Re)3.2.Ω
Coil inductance (Le)1.25mH @ 1kHz
resonance frequency (Fs)26.2Hz
Mecanical coefficient (Qms)3.62
Electrical quality coeficient (Qes)0.71
Total quality coeficient (Qts)0.59
Air movemen (Mms)270g
Compliance (Cms)0.14 mm/N
area surface (Sd²)490.9cm²
Air displaced volume (Vd)932.7 cm3
linera maximum displacement (Xmax)19mm
Optimum cabinet size according to BassBox 6 Pro
Sealed Volume80 Litres
Sealed F334 Hz
Vented Volume140 Litres
Vented F317 Hz
Speaker Power (W RMS)600.0
Speaker TypeSubwoofer
Impedance (Ω)4
Loudspeaker diameter (mm)300.0
Diaphragm typeGlass fiber
Diaphragm typeComposite alloy
Efficiency / Sensitivity (dB)87.0
Max Linear Excursion (Xmax) (mm)2.5
Max Linear Excursion (Xmax) (mm)22.0
Lowest frequency (Hz)20
Highest frequency (Hz)1000
4 reviews
impec en dipole !
Parfait pour mon usage, 3 montés en dipoles.
En 12'' car plus facile a loger et placer au bon endroit en H-frame, bon Qts, Fs basse, xmax rassurant et juste super solide.
Poussés par un xls 1502, sur une octave et demie, une articulation 100 fois meilleure qu’en reflex et 50 fois mieux qu’en clos.
Parfait pour ma pièce, en raccord avec le reste, en dipole également bien sûr :)
This review has been posted for DAYTON AUDIO UM12-22 Ultimax DVC Speaker Driver Subwoofer 600W 2x2 Ohm 87dB 20Hz - 1000Hz Ø30cm
Efficace et très fiable
Cela fait 3 ans que j'ai monté deux UM12-22 dans leurs caissons de 66 litres en clos pour compléter mes Genelec 8040 (coupure à 80 Hz entre les deux avec un filtre actif). La cible étant l'écoute de musique et le home cinéma. Les Dayton sont alimentés par un ampli de deux fois 1200W et il faut ça pour les faire bouger puissamment en mode cinéma. Ils ne descendent pas aussi bas que par le calcul, 40 Hz au lieu de 34 Hz mais une fois dans la pièce d'écoute la fréquence de coupure basse approche les 20 Hz et je n'ai donc pas été obligé de compenser le niveau tel que je l'avais imaginé au début. Donc au final, oui ça cogne bien et c'est très propre, aucun effet de résonance désagréable ou sourde. Attention toutefois avec de gros caissons comme cela, il est fortement recommandé d'équaliser la courbe de réponse pour la linéariser en fonction de votre pièce d'écoute.
Démoniaque !
Ce 30cm est fabuleux dans son domaine !
J’en ai acheté une paire sans trop y croire voulant étendre la réponse de mon system hifi haut-rendement, et je dois dire que je suis resté bouché bée …
C’est ultra nerveux, avec une descente dans l’infra-grave et une tenue en puissance à faire pâlir les sub du commerce à la mode !
Je l’utilise en usage musical dans 80L clos et c’est sublime !
Rapide, nuancé, puissant avec un niveau sonore possible qui semble sans limite !
Vous pouvez y aller les yeux fermés !
Bonjour.
Comme d'hab livraison rapide et très bien emballé,
j'ai longtemps hésiter avant de commander le DAYTON AUDIO UM12-22
j'ai fabriqué un caisson de basse homecinema avec un amplis de 500w RMS LEDGE SVS pour mon DAYTON AUDIO RSS315HF-4 de 109l donc je l'es remplacer par le DAYTON AUDIO UM12-22 et la différence est incroyable beaucoup plus de puissance et des basses fréquences plus profondes au top content de mon achat
 (3)
Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Discover the...
