AUDIO-GD NFB-3DAC 2015 ES9018 DAC DSD / DXD 32bit/384kHz
Reference : 10253
599,00 €tax incl.
499,17 € tax excl.
The NFB-3DAC (2015), the latest addition to the family of non-feeedback analog digital converters, incorporates the USB 32 interface and a new low-noise R-Core transformer.
This new product also has different filters at the output of the converter.
NFB is the acronym for Non-feedback; technology used by Audio-Gd so as not to "color" the sound at the level of the electronics of the output stage giving you a sound of a very professional neutrality.
Its USB32 interface allows you to manage 32 bit 384kHz / DSD sources directly via USB.
The 100% discreet design of this converter is backed by a high power (Class A) power supply.
The 24k Gold Plated RCA and the Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Included Options:
  • Clocks TCXO (DAC)
INGREDIENTS
Interface / ConverterAmanero / Saber ES9018
INPUTS
USBUsb x1
CoaxialRCA + BNC
ToslinkOptical x 1
EXITS
AnalogRCA x 2
ACSSACSS x 2
Features:/ Strong>
  • USB Interface: USB32
  • DSD (64 and 128) / DXD / PCM
  • DAC: ES9018
  • R-Core Transformer
  • High accuracy TCXO clock
Ratio RCA Signal / Noise
116dB
Output impedance
10 ohms
RCA Output Level
2.5V (RCA)
2MA (ACSS)
Input sensitivity
0.5 Vp-p (75 Ohms, Coaxial)
19 dBm (Optical)
USB1.1, USB2.0 (Full Speed, High Speed, Class2)
ACSS Output Level
2 MA
Frequency Response
20Hz - 20KHz -0.2DB
Supported sampling rates
USB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, 384kHz
Coaxial model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 192kHz
Optical model: 44.1kHz, 48kHz, 88.2kHz, 96kHz
DSD 64/128
DXD
Dimensions
Weight
240 x 320 x 80mm
5KG
Accessories
AC power cord X1
USB cable X1
[Img-13676-left-thickbox_default]
[Img-12770-left-thickbox_default]
[Img-12771-left-thickbox_default]
2 reviews
Etonnant !
Sur des instruments qui mettent à nu les faiblesses d’un dac, le piano, les percussions, les cymbales, triangle, métallophone, les voix : une très belle écoute. Profondeur, largeur, justesse tonale, matière, tout y est !
J’ai un Rega dac depuis des années, dans sa gamme de prix, il était ma référence. Comparé au dac du Cambridge Audio Stream Magic 6 V2, 30 secondes d’écoute suffisent…
Ecoute sur casque Grado GS 1000, ampli casque Lehmann audio Linear SE.
This review has been posted for AUDIO-GD NFB-3DAC 2015 ES9018 DAC DSD / DXD 32bit/384kHz
j'ai pris mon temps avant d'écrire ce post. Rodage, vérifications, re-vérifications, bas volume haut volume etc...
Ce dac est une boucherie. Il faut dire qu'il remplace un denon da300usb, très mignon mais en plastique et avec une alim de playstation. 400 euros quand meme, presque le meme prix que celui là...
Avec un ordi-tour préparé (alim gold, foobar, asio, reconfiguration windows), le résultat est sidérant. Un naturel, des détails, une scène sonore...très très méchant.
l'afficheur aurait pu etre moins basique, ca aurait été cool, mais sinon pour le son...
 (5)
