Based on an architecture Tripath in T-Classwith a TA2020 chip, this T-amp will enchant you with its precise and dynamic sound, despite its low maximum power of about 2x20W.
Compact and stylish it is as effective for sounding office audio systems as Bookshelfs in a small volume.
It is more than enough for moderate volume listening, even on low-output 88dB speakers.
Warning, this amplifier may be sensitive to interference from radio equipment such as tuners./ P>
Features:/ Strong>
- 1 x RCA Stereo Plated Gold Input
- HP output via gold-plated and insulated terminals
- Aluminum Case
- Blue LEDs operating.
- HP on / off delay to prevent interference
- Volume control potentiometer
- Overall dimensions: 146.5 x 97 x 37mm
- Power @ 1kHz @ 0.1% THD:
- 7W under 8ohm
- 11W under 4ohm
It is providedwithout power supply.
To power it you can use any 12V power adapter that can supply a minimum current of 1A.
We recommend a linear model for better quality Audio:href = "https://www.audiophonics.fr/fr/alimentations-hi-fi/audiophonics-alimentation-lineaire-regulee-filtre-emi-rfi-12v-2a-25va-p-11375.html" target = " _blank ">Regulated Linear Power RF EMI FilterI 12V 2A 25VA.
The center pin of the power connector will be + 12V.
P>
