AUNE X5s 6TH ANNIVERSARY High Definition Digital Music Player 32bit 384kHz DSD256 CPLD Silver
For its 6th anniversary edition, Aune unveils an updated version of the X5S with an optimized circuit. This 100% digital audio file player supports almost all formats including DSD up to DSD256. It can read WAV, FLAC, APE and DSD formats.
Reference : 14532
249,00 €tax incl.
207,50 € tax excl.
This product has been replaced by the new version, the AUNE X5S 8TH ANNIVERSARY.
Aune X5S 6Th Anniversary
Aune X5S 6Th Anniversary Lecteur de fichiers haute définition 32bit 384kHz DSD256 CPLD Argent
The ARM + CPLD + DSD1793 architecture offers comfortable computing power for digital transport of this gauge. The X5S 6th Anniversary thus offers a very clean signal, with 133.8 dB THD+N @ 1kHz, 0dB and an extremely low jitter of 2.7NS.
Connectors
It has a large OLED screen providing all the essential information to check that the reading takes place in the best conditions and that all the parameters are respected (frequency, bitrate...etc). The X5S 6th anniversary player can be controlled with an I/R remote control (supplied with the exception of the island).
Equipped with a diversified connectivity (AES/EBU - Optical Toslink - RCA Coaxial), it is able to drive a very wide range of audio DACs. In addition, the front of the unit features an SD card reader from which the X5S will be able to read audio files.
If the X5s 6th Anniversary is used with an X1S (same manufacturer), the set benefits from a SPDIF capacity exceeding the standard 192kHz ceiling. Such a coaxial / SPDIF line can run DSD128 - 32bit/384KHz streams autonomously.
Aune X5s 6Th Anniversary Lecteur de fichiers haute définition 32bit 384kHz DSD256 CPLD ArgentAune X5s 6Th Anniversary Lecteur de fichiers haute définition 32bit 384kHz DSD256 CPLD ArgentAune X5s 6Th Anniversary Lecteur de fichiers haute définition 32bit 384kHz DSD256 CPLD Argent
Product typeDigital music player
ClocksCrystek
DisplayOLED
Remote controlYes (battery not included)
RCA output level2Vrms
RCA output frequency response (+/-0.5dB)20Hz - 20kHz
RCA output noise5.4µV
RCA output THD+N-101dB
Supported file formatsWAV : Up to 32bit 384kHz, WAV + CUE
FLAC : Up to 32bit 384kHz, 0-8 level
DSD : DSF / DFF up to DSD256, SACD-ISO
APE : 16bit 44.1kHz
ALAX
AAC
MP3
THD+N-98.25dB @ 16bit 44.1kHz, 1kHz 0dB
-137.8dB @ 24bit 96kHz, 1kHz 0dB
-141dB @ 24bit 192kHz, 1kHz 0dB
Jitter237.6ps
Inputs1x SD Card (Max 128Go, exFAT)
1x USB-A (Max 2Tb, exFAT)
Outputs1x Coaxial
1x Optical
1x AES
1x RCA
Package1x Aune X5s 6th Silver
1x Power supply
1x Remote control
Dimensions171 x 145 x 45mm
InputSD Card
OutputCoaxial SPDIF
OutputOptical Toslink
Max sampling rate384kHz
Max sampling rateDSD256
ColorSilver
For its 6th anniversary edition, Aune unveils an updated version of the X5S with an optimized circuit. This 100% digital audio file player supports...
