AUNE X5s 6TH ANNIVERSARY Lecteur de fichiers Audio Haute définition 24bit DSD (CPLD) Noir
Reference : 13644
249,00 €tax incl.
207,50 € tax excl.
This model has been replaced by the Aune X5s 8Th Anniversary version.
Aune X5S 6th anniversary edition
File Player 384kHz 24-bit DSD256
Aune X5S
For its 6th anniversary edition Aune unveils updated version of X5S with optimized circuit. This audio file player 100% digital supports almost all formats including DSD up DSD128. It can play WAV, FLAC, APE and DSD.
The ARM + CPLD + DSD1793 offers him a comfortable computing power for digital transmission of this size. The 6th anniversary X5S thus offers a very clear signal, with 133.8 dB THD + N @ 1kHz, 0 dB and extremely low jitter of 2.7NS.
Connectors
X5S birthday 6
It has a large screen OLED providing all the essential information to verify that the reading takes place in the best conditions and that all parameters are met (frequency, bitrate ... etc).
The sixth birthday X5S reader may operate with remote control I / R (supplied with the exception of the stack).
Featuring a diverse connectors (AES / EBU - Toslink Optical - Coaxial RCA), it is able to attack a wide range of audio DACs. The front panel also has a SD card slot from which the X5S can play audio files.
Its construction and its specifications make it the ideal companion for a X1S (same manufacturer) which has a 384KHz SPDIF card as well. They to form a very efficient team that can perform accurate DSD256 without needing a computer.
ell internal architecture
ell architecture
Illustration with DAC Aune
Technical characteristics
Product typeFiles player
ClockCrystek
DisplayYes, OLED
Remote controlYes (batteries non included)
RCA output level2Vrms
RCA output frequency response (+/-0.5dB)20Hz - 20kHz
RCA output noise5.4µV
RCA output THD+N-101dB
Supported formatsWAV : Up to 32bit 384kHz, WAV + CUE
FLAC : Up to 32bit 384kHz, level 0-8
DSD : DSF / DFF jusqu'à DSD256, SACD-ISO
APE : 16bit 44.1kHz
ALAX
AAC
MP3
THD+N-98.25dB @ 16bit 44.1kHz, 1kHz 0dB
-137.8dB @ 24bit 96kHz, 1kHz 0dB
-141dB @ 24bit 192kHz, 1kHz 0dB
Jitter237.6ps
Inputs1x SD Card (Max 128Go, exFAT)
1x USB-A (Max 2Tb, exFAT)
Outputs1x Coaxial
1x Optical
1x AES
1x RCA
Package1x Aune X5s 6th
1x Power supply
1x Remote control
Dimensions171 x 145 x 45mm
Pratique et audiophile
Après avoir cherché des jours entiers sur le net, je peux affirmer que ce petit appareil n'a aucun équivalent sur le marché à moins de 300€.
Certes, il ne fait que lire les fichiers numériques à partir d'une carte SD ou d'une clé USB. Mais il le fait bien et cela s'entend immédiatement.
Il est capable de restituer la musique avec une très grande rigueur, sans colorer les timbres, et toujours avec naturel. Son DAC est de bonne qualité, et sa fabrication en alu massif usiné respire la solidité.
Seul bémol, la portée de la télécommande qui est un peu juste (3m environ).
Je viens d'investir dans l'alimentation séparée du même fabricant, et j'ai encore fait un bond en avant en terme de dynamique et d'aération.
This review has been posted for AUNE X5s 6TH ANNIVERSARY Lecteur de fichiers Audio Haute définition 24bit DSD (CPLD) Noir
