By buying this product you get 34 loyalty points
High Definition Audio File Reader ES9038Q2M Bluetooth 5.0 FPGA 32bit 768kHz DSD512 Black
The X5s 8Th Anniversary Edition is the fourth generation of Aune X5 digital file player. It embeds a Freescale 600M processor. It is also capable of handling high resolution streams up to 32bit 768kHz PCM and DSD512. It also adds support for an external clock.
The reading of files is done via SD card thanks to a slot positioned in front and thus easily accessible. It is also possible to connect a USB storage device such as a hard disk.
The digital/analog conversion stage, particularly powerful, is based on an excellent ESS ES9038Q2M DAC chip, a model that has proven itself in many HiFi devices. This one ensures a precise, rich and dynamic restitution.
The X5s 8Th Anniversary also features a Bluetooth 5.0 CSR8675 receiver chip, supporting the high-resolution aptX HD transmission codec. The player can therefore be easily connected to a smartphone in order to stream music remotely.
It can also be used as a Bluetooth transmitter. When files are played from an SD card or USB storage device, the audio streams can be transmitted directly to Bluetooth headphones or speakers.
Aune's file reader integrates an ultra-low jitter PLL and FPGA but also allows the connection of an external clock to achieve an even lower jitter level.
In order to adapt to your listening preferences and your audio system, the X5s 8Th Anniversary offers 7 filters for its line output.
The architecture of the X5s 8Th Anniversary includes an ARM processor that decodes the audio files and then transmits the signal to the FPGA, combined with an ultra-low jitter clock to regenerate the digital signals. This structure allows to offer a particularly detailed and rich sound.
The digital outputs of the Aune X5s 8TH Anniversary use a professional grade, fully isolated digital transformer to deliver extremely pure, interference-free digital signals.
Product type | File reader |
Inputs | 1x SD Card slot 1x USB-A (Host) Bluetooth 5.0 |
Outputs | 1x Coaxial 1x Optical Toslink 1x AES 1x Stereo RCA Bluetooth 5.0 |
DAC Chip | ESS ES9038Q2M |
THD+N (Digital outputs) | -98.25dB @ 16bit/44.1kHz, 1kHz/0dB -137.8dB @ 24bit/96kHz, 1kHz/0dB -141dB @ 24bit/192kHz, 1kHz/0dB |
Jitter | 237.6ps |
Output level (RCA) | 2Vrms |
Frequency response (RCA) | 20Hz-20kHz ±0.5dB |
Noise (RCA) | 5.4µV |
THD+N (RCA) | -101dB |
Supported file formats | WAV : 16/24/32bit - 44.1/48/88.2/96/176.4/192/384kHz FLAC : 16/24/32bit - 44.1/48/88.2/96/176.4/192/384kHz DSD : DSF/DFF DSD64-256 / SACD-ISO APE : 16bit / 44.1kHz ALAC AAC MP3 |
Housing material | Aluminum |
Dimensions | 145 x 171 x 45mm |
Color | Black |
Package | 1x Aune X5s 8Th Anniversary 1x Power supply 1x Remote control |
