CEN.GRAND 9I-806 LITTLE SILVER FOX Headphone Amplifer 15W @ 30Ω 20Hz-20Khz
By buying this product you get 199 loyalty points
Reference : 17758
1 999,00 €tax incl.
1 665,83 € tax excl.
Heaphone Amplifier 15W @ 30Ω 20Hz-20Khz
CEN.GRAND 9I-806 LITTLE SILVER FOX Amplificateur Casque 15W @ 30Ω 20Hz-20Khz
The CEN.GRAND 9I-806 is a headphone amplifier designed to drive high-end headphones. Four output types are available for headphone listening to accommodate the impedance level required for many models. This headphone amplifier delivers top-notch audio performance. Moreover, even if you input a single-ended signal, the internal circuitry will convert it to a balanced signal.  So even if you input a single-ended signal, you'll still get the maximum output power.
Key points :
  • The 9i-806 uses a potentiometer to adjust the volume.
  • Four output modes are available: Normal, BTL, Parrallel and Active ground.
  • Two balanced and two single-ended XLR and RCA inputs.
  • Four different headphone outputs: Balanced XLR 4-pin, 2x Jack 6.35mm, 1x balanced Jack 4.4mm and 1x balanced stereo XLR 3-pin.
The output modes of the CEN.GRAND 9I-806 headphone amplifier
The four output modes will allow you to select the ones that best suit your listening preferences or the characteristics of your headphones. Normal mode is used for low impedance headphones and earphones and BTL mode for high impedance headphones. The Parallel mode is effective for medium impedance headphones, increasing the driving force but not the gain. Finally, the Active Ground mode provides a stronger sense of harmonics and is therefore suitable for listening to the human voice or string instruments. This last mode offers a softer and warmer listening experience.
Connections of the 9I-806 LITTLE SILVER FOX
1Headphones ouputs : 2x XLR 3 pins balanced / 2x Jack 6.35mm stereo single-ended
2Headphone output Jack 4.4mm balanced
3Screen
4Input mode selection
5Power on/off
6Output mode selection
7Headphone output XLR 4 pins balanced
8Volume control
92x Inputs RCA stereo single-ended
102x Inputs XLR stereo balanced
11Power input / Power switch on/off
Product typeHeadphone amplififer
Inputs2* Balanced  stereo XLR
2* Single-ended stereo RCA
Outputs1* Balanced XLR 4-pin headphone output
1* Single-ended dual Jack 6.35mm headphone output (stereo)
1* Balanced Jack 4.4mm headphone output
1* Balanced dual XLR 3-pin headphone output
Frequency response20-20 KHz (0.02%)
Output power15W (30Ω BTL, distortion 0.02%)
Supply voltageAC 220-230V 50/60Hz
ColorSilver
Net weight6.9 kg
Gross weight8.1kg
InputXLR
OutputJack 4.4mm
OutputJack 6.35mm
ColorSilver
ClassN/A
Remote ControlN/A
