DAYTON AUDIO MP1080 Digital Audio Player Portable Player HD 1080P USB / Micro SD
DAYTON AUDIO MP1080 Portable Multimedia Player HD 1080P USB / Micro SD
The Dayton Audio MP1080 is an ultra-portable file player that supports the playback of movies, music and photos in high quality. The device is compatible with SD/SDHC cards as well as USB 2.0 devices such as USB sticks or hard disks.
Reference : 13431
56,90 €tax incl.
47,42 € tax excl.
Shipping date: 17-07-2024.
Dayton Audio MP1080
DAYTON AUDIO MP1080 Lecteur Multimédia Portable HD 1080P USB / Micro SD
The Dayton Audio MP1080 is an ultra-portable file player that supports the playback of movies, music and photos in high quality. The device is compatible with SD/SDHC cards as well as USB 2.0 devices such as USB sticks or hard disks. Supporting a wide range of file formats, the MP1080 allows you to enjoy your digital content on the go or at home.
Automatic and loop playback allows you to enjoy uninterrupted playback. By connecting a USB storage device containing video files, playback of these files will start automatically. It is possible to adjust the playback and select the files to play using the supplied remote control.
When used with a portable hard drive, the MP1080 becomes the ideal storage device for all your media files. The reading quality is similar to that of a computer. The MP1080 is the perfect player for travelling. Its small size allows it to be transported easily. All you need to do now is connect it to a screen to enjoy your content, wherever you are.
The Dayton Audio MP1080 supports Full HD 1080p files and the vast majority of popular formats. On the connector side, it offers an analog output and an HDMI output to connect to any monitor.
Product typeMultimedia player
Inputs1x Slot Micro SD
1x USB-A 2.0
Outputs1x HDMI : 720p (50/60Hz), 1080i (50/60Hz), 1080p (50/60Hz)
1x Jack 3.5mm Analog output: 720 x 576 (PAL), 720 x 480 (NTSC)
Max resolution1920 x 1080px
Supported codecsMPEG1, MPEG2, MPEG4-XVID, DIVX, H.264, H.263, WMV9/VC1, RMVB
Supported videos formatsMKV, AVI, TS/TP, MP4/M4V, MOV, VOB, PMP, RM/RMVB, MPG, M2TS, WMV
Audio bitrate32 - 320kbps
Supported audio formatsMP3, WMA, OGG, FLAC, APE, AAC
Supported photos formatsJPG, JPEG, BMP, GIF, PNG
Output audio level2.0V +- 0.2Vp
SNR> 80dB (1kHz, 0dB)
Dynamic range> 80dB (1kHz, 0dB)
THD<= 0.04%
External storage peripheralsUSB 2.0 up to 2TB NTFS / FAT32 with MBR partition
Remote controlYes (AAA batteries not included)
Power supply5V 2A DC (Requires a US to FR adapter)
Dimensions63.5 x 76.2 x 15.2mm
Package1x MP1080
1x Jack 3.5mm to RCA Composite Cable
1x Power supply
InputMicro SD
OutputJack 3.5mm
OutputHDMI
The Dayton Audio MP1080 is an ultra-portable file player that supports the playback of movies, music and photos in high quality. The device is...
