ELFIDELITY AX-RQ-2 Interface USB 3.0 XMOS to I2S / DSD / SPDIF
Reference : 9061
109,00 €tax incl.
90,83 € tax excl.
True concentrate of technology enclosed in a metal case, this interface USB 3.0based on the now famous XMOSallows to have a high level digital output in coaxial SPDIF with an Asynchronous management of the USB.
Limited to 24bits 192khz through the Coaxial output, this interface allows DIYers to recover the format I2S / DSD 64/128via the connector on the PCB (in this case this interface supports the 384 kHz).
Recognized without drivers in Mac-os and linux this one requires a Windows Driver (delivered on CDrom)
Additional instructions at the bottom of the page.
Features:/ Strong>
  • I2S / DSD direct output on PCB (10 pins)
  • SPDIF output on PCB (3 pins)
  • Asynchronous USB 3.0 input.
  • Compatible with Raspberry pI (Volumio, Picoreplayer, Raspbmc etc ...)
  • Jitter: 4.6 ps
  • Exits :
  • Coaxial Spdif or
  • I2S on PCB (32 bits 384khz)
  • DSD on PCB: DSD 64 (2.8224M, 3.072M), DSD 128 (5.6448M, 6.144M)
  • SPDIF Coaxial to RCA: up to 24 bits, 44.1,48,88.2,96,176.4 and 192 (Khz)
  • Power Supply: USB +5 V (3.75V ~ 5.25V)
  • Dimensions: 125 x 40 x 30 mm
  • Comes with USB 3.0 cable (1.5 m)
  • Weight: 400 g
Specifications I2S:
  • SDOUT: DATA.
  • SCLK: BCLK.
  • LRCK: Word clock.
  • MCLK: masterclock input
[Img-7917-left-thickbox_default]
https://www.audiophonics.fr/images2/8375/8375_XMOS_USB_DSD_1.jpg
On some systems, this interface is defaulted to 384 khz off coaxial output does not allow the management of such a sampling rate.
It should be set to 192 khz or you do not have an ex:
https://www.audiophonics.fr/images2/8375/8375_XMOS_USB_DSD_4.jpg
