By buying this product you get 159 loyalty points
Master Clock OCXO 10MHz Black
This high-performance Gustard C18 external clock is ideal for ensuring perfect synchronization of digital audio signals to improve the sound quality of a HiFi system. The C18 is equipped with an ultra-low noise oscillator.
The oscillator used here is a 10MHz OCXO, designed to promote a constant temperature and thus minimize changes in output frequency caused by temperature variation. Specially designed for audio, it allows you to achieve a greater level of detail, a more realistic sound signature and a higher dynamic range.
The output circuit of the C18 maintains and does not deteriorate the low phase noise signal provided by the main oscillator. The GDRV-P1 can also provide both a sine and a square wave signal to accommodate different devices.
The C18 features a discrete Class A power supply circuit that is highly efficient, providing low ripple and fast response.
Product type | Master clock |
Output frequency | 10MHz |
Frequency accuracy | < ±300ppb |
Frequency stability | < ±50ppb |
Output amplitude | 7dBm @ 50Rz |
Output waveform | Sinus Square |
Output impedance | 50Ω-75Ω (selectable via switch on back of unit) |
Bruit @ 1Hz (TYP) | -110dBc |
Voltage supply | 115-230V AC 50/60Hz |
Consumption | < 15W |
Dimensions | 220 x 170 x 50mm |
Weight | ~ 2.5kg |
Color | Black |
