LINDY HDMI / IR Extension Kit via IP LAN 100Base-T
This HDMI and IR extension kit via IP from Lindy allows a reliable extension of the transmission distance using a network connection. It consists of a transmitter and a receiver modules
Reference : 17027
199,00 €tax incl.
165,83 € tax excl.
Kit d'extension HDMI / IR via IP
Kit d'extension HDMI / IR via IP LAN 100 Base-T
This HDMI and IR extension kit via IP from Lindy allows a reliable extension of the transmission distance using a network connection. It consists of a transmitter and a receiver modules. As a point-to-point connection, the extension supports distances of up to 100m using a Cat.6 cable (sold separately). The kit can also be combined with network switches (not included) for a more complex distribution system.
This system supports resolutions up to Full HD 1920*1080@60Hz 4:4:4 8bit and allows for quality display. The IR extension also allows for easy control via an included IR transmitter and receiver cable.
The HDMI over IP extension delivers full 1080p resolution using a barely perceptible form of video compression. Presentations and static desktop displays/images will have a loss of sharpness similar to mild JPEG compression.
Product typeHDMI / IR extension kit via IP
Transmitter module input1* HDMI
Transmitter module outputs1* Ethernet RJ45
1* IR via Jack 3.5mm
Receiver module inputs1* Ethernet RJ45
Receiver module output1* HDMI
HDMI version1.2
Bandwidth4.95Gbps
Max transmission distance100m
Max resolution1920*1080px @ 60Hz 4:4:4 8bit
HDCP supportPass-through
EDIDPass-through
AudioPCM 2 channels
IR support20-60Hz
CertificationsCE, FCC, RoHS, REACH
Supply voltage5VDC via Jack DC 5.5/2.1mm (power adapters included)
Dimensions (L*P*H)100*65*26mm
Weight / module245g
Package1* Transmitter module
1* Receiver module
1* IR transmitter cable
1* IR receiver cable
2* Power adapters
This  HDMI and IR extension kit via IP  from  Lindy  allows a  reliable extension of the...
