LITTLE DOT DAC_2 Digital to Analog Converter 24bit / 192kHz
By buying this product you get 40 loyalty points
Reference : 5255
409,00 €tax incl.
340,83 € tax excl.
Little Dot declines its DAC_1 in a more ergonomic version, with headphone amplifier and integrated volume control.
The headphone output is amplified by a pair of discrete transistors BD139 / BD140 driven by a chip LME49710.
The conversion section uses the best available chips as well as a 2 quartz clock circuit to ensure an output signal without jitter.
Characteristics :
  • High performance conversion chip WOLFSON WM8740
  • Receiver chip WM8805 ultra low jitter (50ps)
  • Able to process signals up to 24Bits / 192KHz (except USB)
  • Digital over- sampling filter 64fs (> 100kHz) / 128fs (<100kHz) configurable on 2 positions (Soft & Sharp) or totally disengageable
  • Operational base amplifiers for upgrade or upgrade
  • SPDIF digital input on Toslink, BNC & RCA
  • USB DATA input
  • Analog outputs on RCA jacks
  • Transistor Headphone Amplifier
  • Volume adjustment
  • Device supplied with a 75Ω BNC coaxial cable, and an IEC 230V power cord, a USB cable
Technical specifications:
  • Frequesampling rates: 8kHz to 192kHz
  • Quantification: 16 to 24 Bits
  • Digital Audio Inputs: SPDIF to BNC 75Ω Jacks, Coaxial (RCA 75Ω), Optical (Toslink) & USB Input
  • Level of Inputs BNC & RCA: 500mV (RMS)
  • Analog Audio Output: Asymmetrical to RCA Jacks
  • Output Level RCA Unbalanced: 2V Per Channel (RMS)
  • Frequency response: 20Hz to 20KHz (+/- 1db)
  • Signal to Noise Ratio: 110dB
  • Dynamic Range: 117dB
  • Harmonic Distortion: -104dB
  • Power Consumption: 10VA
  • Protection Fuse: 1A
  • Dimensions: 365 x 217 x 61 mm (L x W x H)
  • Weight : 2kg
  • 1 year warranty AUDIOPHONICS
[Img-12423-left-thickbox_default]
[Img-12424-left-thickbox_default]
[Img-12425-left-thickbox_default]
InputBNC
DAC / ADC ChipWM8740
Max sampling rate192kHz
ColorSilver
