MATRIX CUBE - USB DAC SPDIF 24/192 - BNC - RCA - Headphones
DAC with USB inputs - BNC (SPDIF), OPTICAL (SPDIF), coaxial output SPDIF
Input / Output RCA / Headphone Amplifier.
This device is a Digital - Analog Converter and Headphone Amplifier.
Despite its compact size it is equipped with many digital inputs, input analog outputs, and a headphone amplifier.
Its great technical versatility allows multiple configurations:
- DAC directly connected in USB to your computer, to get the most out of your audio files.
- Amplifier Headphone with volume control
- Output Line-Out with fixed volume
- A switch allows you to choose the source of the headphone section either the stereo analog input (MP3, Ipod ...) or the internal DAC.
- Digital pass-trough for a DTS or AC3 signal arriving in optics and requiring external decoding by a DTS decoder.
It incorporates the Jitter Reduction Asynchronous Sample Rate Converter (ASRC).
Download the manual in English
Features:/ Span>
- Diagram 100% symmetrical
- Decoding chips WOLFSON WM8740
- Up to 24Bit / 192kHz
- Integrated headphone amplifier, up to 300 ohms
- RCA quality audio outputs
- Simple DAC (without volume control)
- Output Headphone and analog simultaneously (two amplifier circuits)
Digital Inputs:
- Toslink optics from 44.1 to 192kHz
- Coaxial: 75ohm RCA or BNC (supplied adapter) from 44.1 to 192kHz
- USB: 44.1 or 48kHz USB-B connector (PC only)
Digital Outputs:
- SPDIF Coaxial
- 44 to 192kHz according to input
- Allows even redirecting an AC3 or DTS stream
Analog Outputs:
- RCA: 0 ~ 2V variable volume
- Frequency response: 20Hz - 20kHz
- Signal to noise ratio: 112dB
- Dynamic range: 107dB
- Distortion: 0.0002% @ 1kHz
Analog Input:
Others:
- Weight: 1.1kg
- Dimensions: 205x155x44mm
- Power Consumption: 15W
- Comes with: Power cable, USB cable, BNC adapter -> RCA
