Pack FX-AUDIO FX1002A 2x125W Amplifier 4 Ohm + FX-AUDIO FX01 USB DAC + DYNAVOX RCA Cable
This pack is the ideal choice to have a complete audio system (excluding speakers) for high quality listening from a USB source. It is a powerful and precise package that remains very affordable.
Reference : 13357
115,00 €tax incl.
95,83 € tax excl.
Instead of 117,80 €
Pack content
Pack FX-Audio FX1002A / FX01 / Dynavox RCA
2x125W Class D Amplifier + USB DAC + RCA Cable
Pack FX-Audio FX1002A Amplificateur Class D 2x125W + FX01 Interface USB + Dynavox Câble RCA
This pack is the ideal choice to have a complete audio system (excluding speakers) for high quality listening from a USB source. It is a powerful and precise package that remains very affordable. It consists of an FX-Audio FX1002A amplifier, an FX01 USB DAC from the same brand and finally a Dynavox stereo RCA cable.
Amplificateur Class D FX-Audio FX1002A
FX-Audio FX1002A Amplifier
The FX-Audio FX1002A is a Class D amplifier based on a TDA7498E TI amplifier chip. It is thus able to deliver no less than 2x125W at 4 Ohm, thanks to a high efficiency, which allows it to be associated with many speakers, including some difficult models.
Under its hood, the FX1002A shows a careful design with quality components such as Epcos film capacitors or a double mono preamplifier part with three AOPs on DIP8 support and therefore interchangeable. These AOPs are fast and high bandwidth TL082CP Dual JFETs that provide transparency and dynamism.
Qobuz Review
The FX1002A has been fully tested by Qobuz
Read the review
FX-Audio FX01 USB DAC
The FX-Audio FX01 is a small USB DAC that stands out for its ergonomics and compactness, its design and its electronic architecture. It is equipped with an adaptive USB interface allowing it to support PCM audio files up to 24bit 96kHz.
Its conversion chip is a PCM5102 which provides a high signal-to-noise ratio, very low distortion and a direct DAC output stage, without active components. Such a design represents all the advantages that could be expected from a DAC, without the coloring of the output stages and the harmful audio filters in terms of musicality.
Qobuz Review
Like the FX1002A, the FX-Audio FX01 was granted a full test by Qobuz.
Read the review
DAC USB FX-Audio FX01
Câble RCA Dynavox
RCA Dynavox Cable
This RCA cable that will allow you to connect the FX01 to the FX1002A is part of Dynavox's excellent Perfect Sound cable range. It incorporates 99.99% pure OFC Copper conductors and therefore ensures excellent audio signal conductivity. The RCA connectors are gold plated so that they do not oxidize while maintaining a very good conductivity. Finally, the braided nylon sheath of the cable gives it a very beautiful design and increased mechanical resistance.
FX-Audio FX1002A Specifications
Product typeClass D Amplifier
Max power2x125W @ 4 Ohm, THD 10%, 32V
2x105W @ 4 Ohm, THD 0.1%, 32V
2x60W @ 8 Ohm, THD 10%, 32V
OutputSpeaker terminal
SNR99dB
Distortion0.1%
Power suppleDC 24-36V (included)
Dimensions168 x 95 x 30mm
Weight1.2kg
Accessories1x Power cable
1x Power supply adapter 32V DC 5.9A
FX-Audio FX01 Specfications
Product typeDAC
DAC ChipPCM5102
InputAdaptative USB
OutputGold plated Stereo RCA
USB InterfaceSA9023
SNR> 107dB
Power supplyVia USB
Housing materialBrushed Aluminium
Dimensions92.5 x 40 x 25mm
Weight100g
Accessories1x USB-A to USB-B 1.5m Cable
Dynavox RCA Cable Specifications
Cable typeMale Stereo RCA to RCA cable
Length0.75m
Cable conductor materialOFC Copper 99.99% purity
Connectors platingGold
Cable diameter6mm
SheathBraided nylon
ColorBlack and red
Color ringsYes
Petit mais costaud !
Petit ampli que j'ai acheté pour remplacer une chaîne HI-FI un peu trop encombrante. Je voulais par contre garder les enceintes qui sont très bonnes.
Très surpris par sa petite taille (un gros livre), il est aussi puissant que la chaîne qui pilotait les enceintes auparavant.
Je trouve les voix plus claires, plus distinctes. Tout est plus précis.
Je ne suis plus obligé de pousser le volume pour entendre distinctement les voix ou la musique. C'est vraiment agréable.
C'est peut-être aussi lié au DAC RCA/USB fourni dans ce kit.
Je recommande vivement ce petit (par la taille) kit !
This review has been posted for Pack FX-AUDIO FX1002A 2x125W Amplifier 4 Ohm + FX-AUDIO FX01 USB DAC + DYNAVOX RCA Cable
This pack is the ideal choice to have a complete audio system (excluding speakers) for high quality listening from a USB source. It is a powerful...
