Pack Topping E50 Balanced DAC + L50 Balanced Headphone Amplifier + TCT1 Jack 6.35mm Cables Silver
This Topping pack is composed of a balanced DAC E50, a balanced headphone amplifier L50 and cables Jack 6.35mm TCT1 allowing the connection of both devices. This set will allow you to take advantage of a headphone amplification system with its dedicated digital/analog conversion stage, in order to enjoy an excellent sound quality, rich and precise.
By buying this product you get 39 loyalty points
Reference : 15681
396,00 €tax incl.
330,00 € tax excl.
Instead of 417,91 €
Pack content
Pack Topping
Pack Topping DAC Symétrique E50 + Amplificateur Casque Symétrique L50 + Câbles Jack 6.35mm TCT1
Topping E50 DA
The Topping E50 is a compact and particularly powerful DAC, using proven audio components widely recognized by audiophiles. It is indeed based on an ESS ES9068AS digital/analog conversion chip as well as on a XMOS XU216 USB interface, allowing it to read high resolution files or to decode MQA files. It also benefits from a balanced output on 6.35mm TRS connectors.
View complete product page
Topping E50 DAC ES9068AS XMOS XU216 Symétrique MQA 32bit 768kHz DSD512 Noir
Topping L50 Headphone amplifier
Topping's L50 is a desktop headphone amplifier with an architecture optimized for incredible sound performance. It features a new generation NFCA circuit, based on the one used in the excellent A30 Pro. Versatile, it has a good power reserve and offers a gain control to adapt to all types of headphones.
Topping L50 Amplificateur casque symétrique préamplificateur NFCA Noir
TCT1 Jack 6.35mm TRS Cables
The TCT1 are high quality 6.35mm jack cables. They integrate 6N copper and 6N silver plated copper conductors, ensuring a perfect signal transmission. The contacts of the connectors are gold plated.
TOPPING TCT1 Câble de Modulation Jack 6.35mm TRS Symétrique Cuivre OCC 25cm (La paire)
Product typePack DAC + Headphone amplifier + Jack 6.35mm TRS cables
Pack content1x Topping E50
1x Topping L50
1x Topping TCT1
Topping E50 Specifications
Product typeDAC
DAC ChipESS ES9068AS
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256, MQA
Optical, Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x Balanced Jack 6.35mm TRS
THD+N @ A-WeightingSingle-ended : < 0.0001% @ 1kHz
Balanced : < 0.00009% @ 1kHz
THD @ No-Weighting 90kBwSingle-ended : < 0.0003% @ 20Hz-20kHz
Balanced : < 0.0003% @ 20Hz-20kHz
SNR @ A-WeightingSingle-ended : 124dB @ 1kHz
Balanced : 126dB @ 1kHz
Dynamic range @ A-WeightingSingle-ended : 124dB @ 1kHz
Frequency responseSingle-ended : 20Hz-40kHz (±0.3dB)
Balanced : 20Hz-40kHz (±0.3dB)
Output levelSingle-ended : 2Vrms @ 0dBFS
Balanced : 4Vrms @ 0dBFS
Noise @ A-WeightingSingle-ended : < 1.3µVrms
Balanced : < 2.3µVrms
CrosstalkSingle-ended : -130dB @ 1kHz
Balanced : -139dB @ 1kHz
Output impedanceSingle-ended : 20Ω
Balanced : 100Ω
Supply voltage5VDC
Dimensions129 x 155 x 41mm
ColorSilver
Package1x Topping E50
1x Remote control
1x USB-A to Jack DC power cable
1x USB-A to USB-B cabme
Topping L50 Specifications
Inputs1x Balanced stereo Jack 6.35mm TRS
Outputs1x Balanced XLR 4 poles headphone output
1x Single-ended Jack 6.35mm headphone output
Single-endedBalanced
THD+N @ 1kHz, A-Weighting< 0.00006% @ 780mW, 32Ω< 0.00006% @ 780mW, 32Ω
< 0.00006% @ 333mW, 300Ω< 0.00006% @ 333mW, 300Ω
THD @ 20Hz-20kHz, 90kBW< 0.00008% @ 780mW, 32Ω< 0.0001% @ 780mW, 32Ω
< 0.00008% @ 76mW, 300Ω< 0.0001% @ 76mW, 300Ω
SNR @ Max Out, 1kHz, A-Weighting145dB140dB
SNR @ 50mV, 1kHz104dB104dB
Dynamic range @ 1kHz, A-Weighting145dB140dB
Frequency response20Hz - 40kHz (±0.05dB)20Hz - 40kHz (±0.1dB)
Output level35Vpp @ G=L6.6Vpp @ G=L
35Vpp @ G=M35Vpp @ G=M
37Vpp @ G=H37Vpp @ G=H
Measured noise level @ A-Weighting< 0.7µVrms @ G=L< 0.7µVrms @ G=L
< 0.7µVrms @ G=M< 0.7µVrms @ G=M
< 1.2µVrms @ G=H< 1.2µVrms @ G=H
Crosstalk @ 1kHz-119dB-113dB
Input sensitivity60Vrms @ G=L12.7Vrms @ G=L
12Vrms @ G=M12Vrms @ G=M
2.7Vrms @ G=H2.7Vrms @ G=H
Gain-14.3dB @ G=L-14.5dB @ G=L
-0.1dB @ G=M-0.3dB @ G=M
13.9dB @ G=H13.7dB @ G=H
Output impedance< 0.1Ω< 0.1ΩOutput power
2x 3500mW @ 16Ω, THD+N < 0.1%
2x 2800mW @ 32Ω, THD+N < 0.1%
2x 2000mW @ 64Ω, THD+N < 0.1%
2x 540mW @ 300Ω, THD+N < 0.1%
2x 290mW @ 600Ω, THD+N < 0.1%
Adapter impedance> 8Ω
Supply voltage15V AC via Jack DC (power supply included)
Dimensions129 x 166 x 41mm
ColorSilver
Package1x Topping L50
1x Jack 6.35mm to Jack 3.5mm adapter
1x Power supply 15V AC
TCT1 Specifications
Product typeXLR Cables
ConnectorsMale Jack 6.35mm TRS
Length25cm
Cable external diameterØ8mm
Conductors materialCopper
Silver plated Copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
External sheathBraided nylon
ColorBlack and red
QuantitySold in pairs  (1 cable with red markings, 1 cable with white markings)
E50/L50
I'm overjoyed
This review has been posted for Pack Topping E50 Balanced DAC + L50 Balanced Headphone Amplifier + TCT1 Jack 6.35mm Cables Silver
This Topping pack is composed of a balanced DAC E50, a balanced headphone amplifier L50 and cables Jack 6.35mm TCT1 allowing the connection of both...
