Pack Topping E50 DAC + PA5 II PLUS Amplifier + Jack 6.35mm TRS 25cm TCT1 Cables Silver
This Topping pack includes the E50 DAC, PA5 II PLUS amplifier and TCT1 TRS 6.35mm jack cables for balanced interconnection. This package gives you a complete, affordable, high-performance audio system, capable of delivering rich, accurate sound.
By buying this product you get 54 loyalty points
Reference : 19786
549,00 €tax incl.
457,50 € tax excl.
Pack content
Pack Topping E50 + PA5 II PLUS + TCT1 - Noir DAC ES9068AS + Amplificateur Class D + Câbles Jack 6.35mm TRS
Pack Topping DAC E50 + Amplifier Pa5 II Plus + Cables Jack 6.35mm TCT1
Topping PA5 II Plus amplifier
Topping PA5 II Plus Amplifier
Topping's PA5 II Plus amplifier is a compact and powerful model, adopting a totally symmetrical structure and an innovative Class D amplification circuit, enabling it to develop a significant power of 2x125W into 4Ω with a low level of distortion. The excellent parameterization carried out by the brand's engineers ensures clear, clean and deep sound reproduction, with no background noise. At 5W and 4Ω, THD+N is measured at less than 0.0004%. The PA5 II Plus also incorporates an effective and comprehensive protection circuit, acting against overvoltage, undervoltage, short-circuit, overcurrent and overheating.
On the input side, there's a choice of unbalanced stereo RCA or two 6.35mm TRS jacks for balanced input. Output is via conventional banana-plug HP terminals. There's also a 12V trigger on the rear of the unit, enabling the PA5 II Plus to be connected to other devices and benefit from automatic on/off.
FIND OUT MORE ABOUT TOPPING PA5 II PLUS
 Topping E50 DAC
With its E50, Topping offers a compact, high-performance DAC using tried-and-tested audio components widely recognized by audiophiles. It's based on an ESS ES9068AS digital/analog conversion chip and an XMOS XU216 USB interface, enabling it to read high-resolution files as well as decode MQA files. It also features a balanced output on TRS connectors.
FIND OUT MORE ABOUT TOPPING E50
DAC Topping E50
Cables Jack 6.35mm TRS Topping TCT1
Jack 6.35mm TRS Topping TCT1 25cm cables
Topping's TCT1 cables are high-quality 6.35mm jack cables. They feature 6N copper and 6N silver-plated copper conductors for perfect signal transmission. Each conductor has a cross-section of 0.533mm² (19AWG). Connector contacts are gold-plated for excellent conductivity and resistance to oxidation. Each cable is covered by a robust black and red braided nylon sheath.
MORE ABOUT TOPPING TCT1
Topping PA5 II PLUS Full specifications
Product typeAmplifier
Amplification typeClass D
Inputs1x Single-ended stereo RCA
1x Balanced dual Jack 6.35mm TRS
OutputSpeaker terminals
12V triggerYes
Full specifications on the PA5 II Plus page
Topping E50 Specifications
Product typeDAC
DAC chipES9068AS
USB interfaceXMOS XU216
Inputs1x USB-B
1x Coaxial
1x Optical Toslink
Supported sampling ratesPCM up to 32bit 768kHz
Native DSD up to DSD512
MQA
Remote controlYes
Full specifications on the E50 page
Topping TCT1 specifications
Product typeBalanced Jack 6.35mm TRS cables
ConnectorsMale Jack 6.35mm TRS
Length25cm
Outer cable diameterØ8mm
Conductors materialCopper
Silver plated copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
Outer sheathBraided nylon
Sheath colorBlack and red
This Topping pack includes the E50 DAC, PA5 II PLUS amplifier and TCT1 TRS 6.35mm jack cables for balanced interconnection. This package gives you...
