Pack Topping PA3S Class D Amplifier + D10 Balanced DAC + TCT1 Jack 6.35mm Cables Silver
We propose you this complete Topping pack allowing to develop excellent sound performances. It consists of the PA3s Class D amplifier, the D10 Balanced DAC and the TCT1 cables. You will only need to add a source and speakers to this set to enjoy a complete and particularly efficient audio system.
By buying this product you get 31 loyalty points
Reference : 15679
319,00 €tax incl.
265,83 € tax excl.
Instead of 337,91 €
Pack content
Pack Topping
PA3S Class D Amplifier + D10 BALANCED DAC+ TCT1 Jack 6.35mm Cable Silver
Pack Topping Amplificateur Class D PA3S + DAC Symétrique D10 BALANCED + Câbles Jack 6.35mm TCT1
Topping PA3s amplifier
The PA3s is a small, simple, high performance and affordable balanced Class D amplifier. It is based on two Infineon MA12070 amplifier chips and takes advantage of two balanced and single-ended outputs. It is capable of developing a power of 2x65W under 4Ω with a high efficiency.
View complete product page
TOPPING PA3S Amplificateur Class D Symétrique 2x MA12070 2x65W 4 Ohm Noir
Topping D10 Balanced DAC
With the D10 Balanced, Topping offers an extremely powerful balanced DAC. This one integrates high-end components to favor a limpid and precise reproduction. It includes an ESS ES9038Q2M DAC and a XMOS XU208 USB interface, capable of supporting high resolution audio streams up to PCM 32bit 384kHz and DSD256.
Topping D10 Balanced review by Audio Science Review (Amir)
" It is clear Topping is laser focused on best possible performance at every price point. And at the same time appreciates the importance of providing balanced outputs in desktop products where possibility of ground loops is quite high. Professionals would do well buying the D10 Balanced as well given its 4 volt output and ability to drive longer cables. "
Test du Topping D10 Balanced par Audio Science Review (Amir)
TOPPING D10 BALANCED DAC USB Symétrique ES9038Q2M XMOS XU208 32bit 384kHz DSD256 Noir
TCT1 Jack 6.35mm cables
The TCT1 are high quality 6.35mm jack cables. They integrate 6N copper and 6N silver plated copper conductors, ensuring a perfect signal transmission. The contacts of the connectors are gold plated.
View Complete product page
TOPPING TCT1 Câble de Modulation Jack 6.35mm TRS Symétrique Cuivre OCC 25cm (La paire)
Product typeAmpifier + DAC + cables pack
Pack content1x Topping PA3s
1x Topping D10
1x Topping TCT1
TOPPING PA3S SPECIFICATIONS AND MEASUREMENTS
Product typeAmplifier
Amplifier typeClass D
Amplification chip2x Infineon MA12070
Inputs1x Single-ended stereo RCA
1x Balanced stereo Jack 6.35mm
OutputSpeaker terminals
Single-ended inputBalanced input
THD+N @ 1kHz (A-Weighting)< 0.005% @ 4Ω 5W< 0.0045% @ 4Ω 5W
< 0.004% @ 8Ω 5W< 0.004% @ 8Ω 5W
THD @ 20Hz-10kHz (20kBW)< 0.008% @ 4Ω 5W< 0.007% @ 4Ω 5W
< 0.007% @ 8Ω 5W< 0.006% @ 8Ω 5W
SNR @ Max Out 1kHz, A-Weighting107dB112dB
Dynamic range @ 1kHz, A-Weighting107dB112dB
Frequency response20Hz-40kHz (±0.1dB)20Hz-40kHz (±0.1dB)
Output level46Vpp @ 4Ω46Vpp @ 4Ω
48Vpp @ 8Ω48Vpp @ 8Ω
Noise Bruit (A-Weighting)< 70µVrms< 70µVrms
Crosstalk @ 1kHz-96dB-100dB
Input sensitivity0.92Vrms1.75Vrms
Gain25.2dB19.5dB
Channel balance0.5dB0.5dB
Output power2x 80W @ 4Ω THD+N < 10%
2x 45W @ 8Ω THD+N < 10%
2x 65W @ 4Ω THD+N < 1%
2x 37W @ 4Ω THD+N < 1%
Adapter impedance4-8Ω
Supply voltage26VDC (power supply included)
Dimensions120 x 168 x 40mm
ColorSilver
Topping D10 BALANCED SPECIFICATIONS AND MEASUREMENTS
Product typeDAC
DAC ChipESS ES9038Q2M
USB InterfaceXMOS XU208
Input1x USB-B
Outputs1x Balanced stereo output on Jack 6.35mm TRS (XLR adapters included)
1x Optical Toslink
1x Coaxial
Supported sampling ratesUSB input : PCM up to 32bit 384kHz, Native DSD up to DSD256, DSD DoP up to DSD128
Coaxial / Optical : PCM up to 24bit 192kHz, DSD DoP up to DSD64
THD+N @ 1kHz, A-Weighting< 0.00012%
THD< 0.00015% @ 20Hz-20kHz
SNR @ 1kHz, A-Weighting125dB
Dynamic range @ 1kHz, A-Weighting125dB
Frequency response20Hz-20kHz (±0.2dB)
Output level4.2Vrms @ 0dBFS
Noise< 2.4µVrms
Crosstalk @ 1kHz-141dB
Channel balance0.3dB
Output impedance88Ω
Supply voltage5VDC 0.5A via USB
Dimensions103 x 146 x 37mm
Weight340g
ColorSilver
TCT1 Specifications
Product typeJack 6.35mm cables
ConnectorsMale Jack 6.35mm TRS
Length25cm
Cable external diameterØ8mm
Conductors materialCopper
Silver plated Copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
External sheathBraided nylon
ColorBlack and red
QuantitySold in pairs (1 cable with red markings, 1 cable with white markings)
We propose you this complete Topping pack allowing to develop excellent sound performances. It consists of the PA3s Class D amplifier, the D10...
