Topping TP21 Tripath Amplifier TA2021B
The TP21 is a class-T amplifier based on the TA2021 chipset.
The volume control is accentuated by subtle blue LED lighting.
A special feature of the TP21 is the headphone output on the front panel. in fact it has its own pre-amp that deactivates the speakers when a headset is plugged in and can easily drive any headphones in the 16-200 Ohm range.
In addition, it is entirely made of brushed aluminum and has an elegant design.
So, if you are looking for more power in a small amplifier, the Topping TP21 is a great choice.
P>
Features: Strong>
- T-Amp: Tripath TA2021B
- Signal to Noise Ratio (SNR): 100dB
- Dynamic range: 100dB
- IHF-IM Distortion 0.1% @ 1W, 4ohm
- THD Distortion:
- 0.05% @ 13W, 4ohm
- 0.1% @ 15.5W 4ohm
- 10% @ 25W 4ohm
- 10% @ 14W 8ohm
- Output power: 25W x 2 (4 ohms), 14W x 2 (8 ohms)
- IHF-IM Distortion: 0.1% @ 1W, 4 ohms
- Power Supply: DC 12V ~ 14.6V, 5A, 5.5mm x 2.1mm jack
- Headphone output (3.5 mm) x 1
- Power efficiency: 81% @ 25W, 4 ohms, 88% @ 13.5W, 8 ohms Li>
- Helmet-AMP
- Output power 2 x 60mW @ 16ohm, 2 x 120W @ 32ohm
- THD Distortion
- Size: 113 x 43x 172 mm
- Weight: 620 g
- Components:
- Volume control: CS3310 Li>
- TOKO
- ALPS
- Resistance DALE Li>
- Capacitors ERO, EPCOS
P>
P>
P>
P>
P>
P>
