TOPPING VX1 Vertex Class T digital amplifier 24bit/96kHz USB DAC Headphone amplifier
Reference : 9842
119,90 €tax incl.
99,92 € tax excl.
The TOPPING VX1 is a versatile device of a formidable efficiency designed with high quality electronic components.
Based on a Class-T Tripath architecture with a TA2021B chip, this T-amp delivers a precise and dynamic sound, despite its maximum power of approximately 2x25W.
It is enough for moderate volume listening, even on low-efficiency 88 dB speakers.
DAC USB, it incorporates a Phillips UDA1351TS converter, a VT1620A USB interface and an OPA2134 PDO.
Features:/ Strong>
  • Class T Amplifier: Tripath TA2021A 2x25 Watts
  • Output power: 2 x 15W under 8 ohms, 2 x 25W under 4 ohms
  • Frequency response: 20Hz - 20kHz to 1.1dB
  • THD + N: 0.019% at 1kHz
  • Input Sensitivity: 420mVrms
  • Gain: 27.2dB at 1kHz
  • Output resistance: 0.19 Ohm
  • Headphone Amplifier:
  • Supported impedances: 16 to 300 Ohms
  • Output Power: 140mW at 32 Ohm
  • THD: 0.002% @ 45mW, 32 Ohm
  • Input Sensitivity: 1.1Vrms
  • Gain: 6dB at 1kHz
  • DAC USB:
  • Phillips UDA1351TS
  • THD: 0.0082% at 1kHz
  • Sampling rate: 24bit 96kHz
  • Signal Noise Ratio: 101dB
  • Components:
  • ALPS Potentiometer
  • Resistance KOA
  • CondeNichicon, WIMA
  • Relay TAKAMISAWA
  • Power supply DC 14V 4A included
  • Inputs: RCA, USB-B
  • HP compatible terminal strip outputs
  • Headphone output 6.35mm
  • Supplied with adapter 3.5mm to 6.3mm jack, USB-A cable to USB-B and user manual
  • Dimensions: 50x132x200mm
  • Weight: 700g
[Img-10730-left-thickbox_default]
[Img-10731-left-thickbox_default]
[Img-10732-left-thickbox_default]
[Img-10733-left-thickbox_default]
[Img-10734-left-thickbox_default]
[Img-10735-left-thickbox_default]
[Img-10736-left-thickbox_default]
[Img-10737-left-thickbox_default]
