Max sampling rate
DAC / ADC Chip
Class
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 15 A
Input
Output
Power Supply
Remote Control
Networking
Streaming services
Color
Cyrille S.
Bon transport
Stian L.
A very good and powerful amp
Paul C.
D'une remarquable qualité
HiFi Power Supply
  • Ref : 14749
    In Stock
    This AC adapter takes an input voltage of 100-240VAC to output 48VDC 7.3A (350W). The components are integrated in a robust aluminum chassis that dissipates the heat generated by the components. The power supply ensures a very low ripple to provide a clean electrical signal to your HiFi devices.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 14032
    In Stock
    This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the sound reproduction quality of the latter. Particularly practical, the P50 has 2 USB-A outputs of 5V 1A and 1 DC 5.5/2.1mm jack output of 15V 1A. It is therefore possible to supply several devices with a single...
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 14047
    In Stock
    In Stock
  • Ref : 18915
    This ultracapacitor power filter module enables you to supply a clean 5-24V DC current to power your devices, and supports a maximum current rating of 10A. It is made up of no less than 10 high-quality WIMA supercapacitors.
    42,90 € 35,75 €Ex.
    In Stock
  • Ref : 18529
    In Stock
    This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer system. Input is via a USB-C port and output via a USB-C or USB-A port.
    39,90 € 33,25 €Ex.
    In Stock
