Max sampling rate
DAC / ADC Chip
Class
Input voltage (V)
V
V
Output voltage (V)
Output current (A)
0 A - 15 A
Input
Output
Power Supply
Remote Control
Networking
Streaming services
Color
Manque d 'info
Cette carte doit sûrement valoir le coup. Je ne le sais pas car l'opération de montage de la carte de régulation ainsi que...
Alexandru Ovidiu A.
Magic
Robert C.
En alu et complète avec...
HiFi Power Supply
  • Ref : 14749
    In Stock
    This AC adapter takes an input voltage of 100-240VAC to output 48VDC 7.3A (350W). The components are integrated in a robust aluminum chassis that dissipates the heat generated by the components. The power supply ensures a very low ripple to provide a clean electrical signal to your HiFi devices.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 14032
    In Stock
    This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the sound reproduction quality of the latter. Particularly practical, the P50 has 2 USB-A outputs of 5V 1A and 1 DC 5.5/2.1mm jack output of 15V 1A. It is therefore possible to supply several devices with a single...
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 14047
    In Stock
    In Stock
  • Ref : 18915
    This ultracapacitor power filter module enables you to supply a clean 5-24V DC current to power your devices, and supports a maximum current rating of 10A. It is made up of no less than 10 high-quality WIMA supercapacitors.
    42,90 € 35,75 €Ex.
    In Stock
  • Ref : 18529
    In Stock
    This 5V USB filter allows you to obtain a clean power supply for your Hi-Fi devices thanks to two 20F - 3.0V capacitors as well as an intelligent buffer system. Input is via a USB-C port and output via a USB-C or USB-A port.
    39,90 € 33,25 €Ex.
    In Stock
