ALLO SHANTI Dual Regulated Linear Power Supply 5V 3A / 5V 1A
The Allo Shanti is a regulated linear power supply with a dual 5V 3A and 5V 1A output. It is therefore particularly useful for powering two small devices simultaneously without multiplying the number of power supplies. In addition, its intelligent design allows it to offer exceptional performance.
Reference : 14009
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 16-04-2025.
Allo Shanti
Allo Shanti Alimentation Linéaire Régulée Double 5.1V 3A / 5.1V 1.5A
The use of linear power supply (LPS) in a HiFi audio system has always been an excellent way to improve the playback of the system. However, some problems remain: the price of these feeds and the inability to find product data. It is with a view to correcting these problems that Allo offers the Shanti food.
It incorporates an excellent R-Core transformer, ideal for limiting noise and EMI interference. This transformer has a double output, galvanically isolated, delivering 5V 3A and 5V 1A in order to be able to supply several devices.
An independent filter is used for each power rail. A large series of capacitors reduces the 50/60Hz noise and then an active filtering followed by an LDO maintains a stable voltage. Since LDOs offer a poor transient response and impedance, a last active filter with a good transient response is integrated. This is followed by 15000µF capacitors. The Allo Shanti then embeds super capacitors in the output circuits. These allow the power supply to achieve excellent impedance and transient response. Finally, the power supply also uses an AC line filter and the AC section is grounded at the box. This intelligent design allows a noise level of 80nV (0.08µV on the 0Hz-20kHz frequency band)
Allo Shanti Alimentation Linéaire Régulée Double 5.1V 3A / 5.1V 1.5AAllo Shanti Alimentation Linéaire Régulée Double 5.1V 3A / 5.1V 1.5A
Product typeDual regulated linear power supply
Input voltages115V
230V (switchable)
Output voltage / current5V 3A
5V 1A
InputIEC C14
Outputs2x Jack DC 5.5/2.1mm (1.5m)
Adaptateurs Jack DC livrés1x Jack DC 5.5/2.1mm vers Jack DC 4.7/1.7mm
1x Jack DC 5.5/2.1mm vers Jack DC 4.0/1.7mm
1x Jack DC 5.5/2.1mm vers Jack DC 3.5/1.35mm
1x Jack DC 5.5/2.1mm vers Micro USB
1x Jack DC 5.5/2.1mm vers USB-C
Dimensions (LxPxH)299 x 106 x 55mm
Net weight2.1kg
IEC CableDelivered
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)5.0
Output current (A)3.0
Output current (A)1.0
Input voltage (V)115.0
Power SupplyRegulated Linear Power Supply
24 reviews
Le top qualité prix!
Bonjour, j ai acheté cette alimentation pour mon phono limetree 5v , j ai testé avec cable standard , c est deja bien ,puis avec un cable belden,iec iego or et bals schuko , c est encore mieux . Avec cable standard je mettrrais 4 etoiles et avec un cable meilleure 5 etoiles .belle finition , on gagne en silence ,donc details ,precision, en timbre,douceur,tenue, basse plus punchy , un bas medium plus epais , je la recommande vivement avec un cable digne !
This review has been posted for ALLO SHANTI Dual Regulated Linear Power Supply 5V 3A / 5V 1A
Happy it makes a great difference
I have a Chord mojo and a hifiberry dig+ pro. Before I was using a power bank, and there was a clear difference between coaxial and toslink, toslink sounded 3d but a little less decisive, and coaxial was more impactfull but 2d, now both inputs sound equally 3d, clearly there was some electrical noise coming through coaxial that affected the dac which by the way is not galvanically isolated and this psu solved the problem, I'm very happy with this result, in the future I plan on powering a Chord qutest and allo digione signature with this
Opens up the soundstage but may require burn-in
Still waiting to form my final opinion on the Shanti. I am powering a RPI4 via usb to my Ares II Dac.
Going from a wallwart to a powerbank was a revelation - reducing sibilance, increasing width and depth by making the background blacker. It also brought a more controlled, albeit lacking bass.
With the Shanti the bass is back but a bit closer to what you get with a wallwart - more of it but less controlled. The sound is more dynamic than a powerbank. You definitely get more details as well but this comes at the cost of of a more sibilant and somewhat fatiquing sound. I definitely turned down the volume by about 10db for prolonged listening.
Again, I want to stress this is after less about10 hrs of listening.
I will continue listening and burning in the Shanti and then amend my review to reflect my final observations.
Allo Shanti
Significant sonic upgrade to any Hi-Fi gear.
alimentation très efficace
sur un couple Raspberry + Allo Boss, ça fonctionne vraiment très bien.
Quel dommage que Allo ne la propose plus !
Mais bizarrement, elle est toujours apparemment disponible ici
https://www.allo.com/sparky/shanti.html
mais pas là
https://www.allo.com/sparky-eu/shanti.html
Question à Audiophonics :
pourra-t-on espérer une nouvelle disponibilité sur ce produit dans l'avenir ?
ou alors un produit de remplacement (éventuellement développé par vous-mêmes) ?
cdt
Cette alimentation est vraisemblablement définitivement arrêtée ...
The Allo Shanti is a regulated linear power supply with a dual 5V 3A and 5V 1A output. It is therefore particularly useful for powering two small...
