AUDIOPHONICS Double Regulated Linear Power Supply 2x 12V 1.25A 30W T-Amp V-DAC2 LT1084
The Audiophonics team is proud to be able to offer you a regulated linear power supply for the clean supply of small amplifiers, DACs, etc. It has two lockable GX16 format (aviation type) outputs, each outputting a voltage of 12V 1.25A.
Reference : 8896
99,00 €tax incl.
82,50 € tax excl.
Regulated linear power supply
Alimentation linéaire régulée double 2x12V 1.25A 30W T-Amp V-DAC2 LT1084
The Audiophonics team is proud to be able to offer you a regulated linear power supply for the clean supply of small amplifiers, DACs, etc. It has two lockable GX16 format (aviation type) outputs, each outputting a voltage of 12V 1.25A. The GX16 to DC 5.5/2.1mm jack cables with ferrites are supplied, as well as the IEC C13 / Schuko cable. The power supply is equipped with a dual digital display and all components are integrated in a robust 100% Aluminium housing. This food represents one of the best quality/price ratio on the market.
Product typeDouble regulated linear power supply
Input voltageAC 220V
Output Voltage / Current2x 12VDC 1.25A
Power30W
Input connectorIEC C14 (IEC to Schuko cable NOT included)
Output connectors2x GX16 2 poles (GX16 to Jack DC 5.5/2.1mm included)
RegulatorLinear Technology IC LT1084
Housing materialAluminium
Dimensions145 x 130 x 55mm
Weight3kg
Package1x Double regulated linear power supply
2x GX16 2 poles to Jack 5.5/2.1mm cables
InputIEC C14
OutputGX12
Output voltage (V)12.0
Output current (A)1.25
Input voltage (V)230.0
Power SupplyLinear
surprenant
Acheter pour remplacer l alimentation standard d'un processeurs correcteur de basse SMS Velodyne, le changement est radical.
la basse est franche, ça NE BAVE PLUS. mon PB 2000de chez SVS a bien été paramètré il résonne quasiment plus.
Je ne regrette pas mon achat (mais pensez au câble d alimentation non inclus)
This review has been posted for AUDIOPHONICS Double Regulated Linear Power Supply 2x 12V 1.25A 30W T-Amp V-DAC2 LT1084
The Audiophonics team is proud to be able to offer you a regulated linear power supply for the clean supply of small amplifiers, DACs, etc. It has...
