Cette alimentation me permet d'alimenter une chromcast, une chromcast audio et un switch. Le tout pouvant être coupé d'un seul coup plutôt que de rester alimenté en permanence. Elle est assez stable entre 5V et 5.2V. Parfait
This linear regulated power supply is designed to deliver stable power to any of your amplifiers, DAC, etc ... It works with two separate toroidal transformers and is ideal to minimize as much as possible distortions and power-related noises in your sensitive devices.
Coming in a 100% aluminum casing, this power supply is protected parasites occuring from other nearby electrical devices.
A digital display shows in real time the voltage supplied, it allows the user to confirm in just a glimpse that no anomally are present.
Output is two USB ports and two Locking output type Aviation-type.
With its low price, this power supply is one of the best value for money on the market.
Type | linear regulated power supply |
Housing | Aluminum |
Regulator | Linear Technology LT1086 IC |
Input Voltage | AC 220-240V |
Voltage / output current | 2x 5V 1.5A DC |
Outputs | 2x USB-A 2x Micro Aviation (red = positive / black = negative) |
Power | 2x 7.5W |
Digital display | x2 |
Dimensions | 145 x 135 x 60 mm |
Weight | 1.4kg |
Package Contents | |
GX cable 16 to DC jack 5.5 / 2.1mm | x2 |
USB 2X5V regulated 1.5A power | x1 |
Input | IEC C14 |
Output | GX12 |
Color | Black |
Output voltage (V) | 5.0 |
Output current (A) | 1.5 |
Input voltage (V) | 230.0 |
Power Supply | Linear |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Thierry R.
Jerome V.
Jerome V.
