AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 16V 1.25A 25VA
4.8 / 5
Reference : 11374
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 27-02-2025.
Here alimentation linéaire 16v régulée audiophile HIFIthe 1.25A audiophile regulated power supply for any Hifi device running on 16V.
Here is a regulated and stable linear power supply for any high quality DIY audiophile project. All the necessary technical refinements are incorporated into this dedicated audio power supply.
EIt includes a Hexfet IRF controller of series 34Z driven by low-noise OP Analog-Device and not an integrated circuit. The incorporated EMI RFI filtering ensures a very low (ripple) noise of electrical pollution (- of 100mv).
Thecomponents of this power supply are of first quality with DALE resistors and 4 capacitors of filtering BC of 220μf each. The benefits of a linear quality feed are better readability of the acute medium and a much better cut out.
nsaidsi this regulated linear power solution developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two DC 5.5 / 2.1mm output jacks, this power supply with an extremely stable 25VA transformer even under heavy load will allow you to make the best of audio connected.
Specificaes:
  • Case: 100% Brushed and sanded aluminum
  • Black Anodized
  • Input Voltage: AC 220V
  • Output Voltage / Current: 16V 1.25A DC
  • Voltage adjustment possible by screw potentiometer from 15V up to 24V
  • Outputs: 2 outputs Jack DC 5.5 / 2.1mm
  • IEC socket
  • Shielded molded anti-vibration transformer 25VA
  • AOP-controlled HEXFET IRF-type controller
  • EMI RFI filter with chokes and film capacitors
Dimensions and weight:
  • 174 x 100 x 51 mm
  • Weight: 0.850kg
  • 1x DC 5.5/2.1mmm jack cable with 75cm ferrites supplied
  • Power cable not included
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)16.0
Output current (A)1.25
Input voltage (V)230.0
Power SupplyLinear
5 reviews
Irek
Excellent product! My Thorens TD 318 sounds better. Only minus is the EXTREMLY bright white "power on" LED. Please modify ASAP.
This review has been posted for AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 16V 1.25A 25VA
Absolute reliability
My dealings with audiopnoics: Australia to France, have been reliable in every way possible, Thanks.
Definite upgrade to Topping DX3 Pro+
To my ears, this linear PSU eliminated the tendency of my Topping DX3 Pro+ to sound slightly thin & edgy. Definitely worth the money. The only downside is the ridiculously bright white LED on the front panel.
bon produit
Great service by Audiophonics, good product.
Hugo W.
Goede voeding,mooi gemaakt,
