Acheté en complément d'un raspberry Pi 3+ et d'un AUDIOPHONICS I-SABRE V4 DAC ES9023 TCXO. Aucun bourdonnement à signaler et tensions parfaites.
Je recommande
Regulated linear power supply, EMI/RFI Filter 7V 2A 25VA
Here is the low noise regulated 7V 2A audiophile power supply for any device running on the iSabre V3 / V4 and its specific regulation. Now the Rapstouch touchscreen player with iSabre V3, as well as the Raspdac with iSabre V3 / V4 finally have the regulated and stable linear power supply for any high quality audiophile DIY project. All the necessary technical refinements are incorporated into this dedicated audio power supply. It includes a 34n series Hexfet IRF controller driven by an OP Analog-Device amplifier and not an integrated circuit. The built-in EMI RFI filtering ensures very low electrical pollution noise (-30mv).
The benefits of a linear power supply for our DAC iSabre V3 are a better readability of the high-pitched midrange and a much better detour bass. Thus this regulated linear power supply solution developed for the DAC iSabre V3 competes with much more expensive Streaming solutions. Equipped with a 100% Aluminium housing and two 5.5/2.1mm DC jack outputs, this extremely stable power supply even under heavy load will allow you to get the most out of the connected audio elements.
The power supply is supplied with a 5.5/2.1mm DC jack male/male cable with 75cm ferrites.
This power supply is supplied in 7V. However, it is possible to adjust this voltage to 6V.
compatible devices :
RaspDAC I-Sabre V4 - DIY Kit
RaspDAC I-Sabre V4 - Audiophile streamer
RaspTouch I-Sabre V4 - Tactile Audiophile streamer
Product type | Regulated linear power supply |
Input voltage | AC 220V |
Output Voltage / Current | 7V 2A (Max continue) 7V 3A (Max 5 min) |
Outputs | 2x Jack DC 5.5/2.1mm |
Transformer | Molded anti-vibration shielded 25VA |
Regulator | IRF HEXFET type, drive by AOP |
EMI / RFI Filter | With self and film capacitors |
Power supply noise | Ripple < 100mV |
Housing material | Brushed Anodized Aluminium |
Power supply | IEC (Included cable) |
Dimensions | 174 x 100 x 51mm |
Weight | 850g |
Color | Black |
Package | 1x Audiophonics linear power supply 1x Jack DC 5.5/2.1mm male/male with ferrites 75cm |
Input |
Output |
Color |
Output voltage (V) |
Output current (A) |
Input voltage (V) |
Power Supply |
Average votes 4.6 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Gilbert T.
Claude H.
Nicolas V.
John W.
John W.
