AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 9V 2A 25VA
This is the audiophile low noise 9V 2A regulated power supply for any device operating under 9V DC.
4.9 / 5
Reference : 15143
75,00 €tax incl.
62,50 € tax excl.
Audiophonics Regulated linear power supply
Regulated linear power supply, EMI/RFI Filter 9V 2A 25VA
Alimentation linéaire régulée filtre EMI RFI 6-7V 2A 25VA
This is the audiophile low noise 9V 2A regulated power supply for any device operating under 9V DC. From now on our DAC EVO-SABRE has its own stable regulated linear power supply for any audiophile high quality DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio. It includes a 34n series Hexfet IRF Hexfet regulator driven by OP Analog-Device amplifier and not an integrated circuit. The built-in EMI RFI filtering ensures a very low noise level of electrical pollution (- 30mv).
Equipped with a 100% Aluminium case and two 5.5/2.1mm DC jack outputs, this extremely stable power supply, even under heavy load, will allow you to get the best out of the connected audio elements.
The power supply is supplied with a 5.5/2.1mm DC jack male/male cable with 75cm ferrites.
This power supply is supplied in 9V.
Product typeRegulated linear power supply
Input voltageAC 220V
Output Voltage / Current9V 2A (Max continue)
9V 2.5A (Max 5 min)
Outputs2x Jack DC 5.5/2.1mm
TransformerMolded anti-vibration shielded 25VA
RegulatorIRF HEXFET type, drive by AOP
EMI / RFI FilterWith self and film capacitors
Power supply noiseRipple < 100mV
Housing materialBrushed Anodized Aluminium
Power supplyIEC (Included cable)
Dimensions174 x 100 x 51mm
Weight850g
Package1x Audiophonics linear power supply
1x Jack DC 5.5/2.1mm male/male with ferrites 75cm
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)9.0
Output current (A)2.0
Input voltage (V)230.0
Power SupplyLinear
13 reviews
HOT
It gets very hot and uses twice the energy the little Meanwell PSU uses. I frankly cannot heat much of a difference in my setup. Overall not worth it for me.
Audiophonics Hypex amp, EVO DAC, PMC TwentyFive.23
This review has been posted for AUDIOPHONICS LPSU25 Linear Regulated Power Supply EMI RFI Filter 9V 2A 25VA
Power supply for TAGA Harmony DA-400
Bought to improve the DAC power supply, instead of the default switching power supply (which wasn't terrible by the way).
The build quality (I'm assuming it's from China) is good, with a solid case that also does the job of a heatsink for controlling MOS-FET.
The sound became more structured, and less lively (as it happens with switching power supplies) but more accurate, and the soundstage (space) gained in openness.
I will still experiment with AC and DC power cables and increase the capacitance of the capacitors at the output of the power supply.
Excellent !
Belle esthétique et finition.
Silencieuse.
Livraison rapide et bien emballé.
Je recommande
Very good
This replaced an IfI iPower 9V for my SOTM-200-Neo streamer. First of all - the make is solid and robust and gives an impression of reliability and safety. Secondly, the sound seems to have improved - the space enhanced, the bass more controlled, and the highs unvealed. Will buy a 12V version for my DAC when the finances allow :).
Very good
