This AC adapter supports 176-264V AC input and supplies 48V DC 5A (250W) via its GX16 connector output. The AC adapter's components are housed in a robust aluminum chassis for efficient heat dissipation. Specifically, inside the chassis is an MP-H250S48 switch-mode power supply module with PFC (Power Factor Correction) directly mounted on a heat sink for heat dissipation. The circuit also incorporates protection against overcurrent, overvoltage, thermal overshoot and short-circuit. AC input is via an IEC C14 connector and output via a GX16 connector.
Product type | Switeched mode power supply |
Chassis material | Aluminum |
Input | IEC C14 |
Output | 1x GX16 |
Input voltage | 176-264V AC 50/60Hz |
Output voltage | 48V DC 5A |
Power | 250W |
Precision of voltage stability | ±1% |
Dimensions | 102 x 208 x 50mm |
Net weight | 1.1kg |
Package | 1x Audiophonics power adapter 1x Standard IEC C13 to Schuko male power cable 1x Power cable GX16 to multiple DC jack 5.5/2.5mm and 5.5/2.1mm |
Input | IEC C14 |
Output | GX16 |
Color | Black |
Output voltage (V) | 48.0 |
Output current (A) | 5.0 |
Input voltage (V) | 220.0 |
Input voltage (V) | 250.0 |
Input voltage (V) | 260.0 |
Input voltage (V) | 190.0 |
Input voltage (V) | 210.0 |
Input voltage (V) | 240.0 |
Input voltage (V) | 180.0 |
Input voltage (V) | 230.0 |
Input voltage (V) | 200.0 |
Power Supply | SMPS |
