High quality power supply for Chord Hugo TT2 DAC which needs a maximum of 4 Amp
Low heat dissipation temperature on the heatsink
Cette regulated linear power supply 15V 5A with two jack outputs on 5.5 / 2.1 & 5.5 / 2.5, is dedicated for HiFi audio devices requiring clean and neat power.
By buying this product you get 26 loyalty points
Cette regulated linear power supply 15V 5A with two jack outputs on 5.5 / 2.1 & 5.5 / 2.5, is dedicated for HiFi audio devices requiring clean and neat power, and MADE IN FRANCE.
It will bring back background noise, a lowering of the "ripple" harmful to the jitter on digital audio devices such as DAC or high fidelity streamers. The result is an improvement of the readability of the acute medium with a less digital sound, a contribution, a seating of the timbre, and a better dynamic bass.
The components of this power supply are of first quality:
Thus, this regulated linear power supply developed by our team comes to compete with more expensive solutions.
Equipped with a 100% Aluminum case, two Jack DC 5.5 / 2.1 & 5.5 / 2.5, this power supply with an extremely stable 100VA transformer even under heavy load, and will allow you to make the best of connected audio components requesting from 15V up to 5A.
The female DC jack connectors of the PSU-HC require the use of cables with a long male DC jack connector (14.5mm).
Input | IEC C14 |
Output | Jack DC 5.5/2.1mm |
Output | Jack DC 5.5/2.5mm |
Color | Black |
Output voltage (V) | 15.0 |
Output current (A) | 5.0 |
Input voltage (V) | 230.0 |
Power Supply | Linear |
Average votes 4.3 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Javier C.
Louis F.
Jean Francois V.
antoine L.
