Respire la qualité
This PSU-HC regulated linear power supply provides a clean and stable 5V 5A output voltage and current. At the output are two DC jack connectors, one in 5.5/2.5mm format and the other in 5.5/2.1 format to adapt to different configurations.
By buying this product you get 26 loyalty points
AUDIOPHONICS PSU-HC Regulated Linear Power Supply 5V 5A 60VA
This PSHP regulated linear power supply provides a voltage and output current of 5V 5A. At the output are two DC jack connectors, one in 5.5/2.5mm format and the other in 5.5/2.1 format to adapt to different configurations.
The use of such a power supply in an audio system is a real plus in terms of playback quality. Indeed, providing a clean and stable electrical signal, it allows a reduction in background noise and a lowering of the ripple harmful to jitter on digital audio devices such as a DAC or a high-fidelity streamer. In use, we notice an improvement in the readability of the high-pitched midrange with a less digital sound, a beautiful base of the tones as well as a better bass dynamics.
Under the hood of this power supply are hidden quality components, ideal for audio use, and allowing this power supply to provide such performance. There are metal resistors, 10 6000µF/35V filter capacitors, a Micrel MIC2975BWT voltage regulator and an EMI/RFI filter.
These components are integrated into a robust and robust brushed and black anodized Aluminium housing with the most beautiful effect. To dissipate the heat from the components, the cover of the unit incorporates slots and the side of the unit is equipped with a heat sink. This careful design allows this regulated linear power supply developed by our team to compete directly with more expensive solutions.
The female DC jack connectors of the PSU-HC require the use of cables with a long male DC jack connector (14.5mm).
Product type | Regulated linear power supply |
Input voltage | AC 220V (IEC Cable sold separately) |
Output voltage | 5V DC / 5A (7,5A max, thermal limited) |
Outputs | 1x Jack DC 5.5/2.5mm 1x Jack DC 5.5/2.1mm |
Transformer | 60VA |
Voltage regulator | Micrel MIC2975BWT |
Material | Brushed and anodized Aluminium |
Dimensions | 240x170x60mm |
Weight | 2,4kg |
Color | Black |
Input | IEC C14 |
Output | Jack DC 5.5/2.1mm |
Output | Jack DC 5.5/2.5mm |
Color | Black |
Output voltage (V) | 5.0 |
Output current (A) | 5.0 |
Input voltage (V) | 230.0 |
Power Supply | Linear |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Cyril J.
Jyrki K.
