Linear Power Supply 9V DC 1A for Aune X1s Pro / X8 / T1s / X5s Silver
The XP2 is part of the second generation of XP power supplies adapted to Aune's X/T products. It is a high-end power supply capable of providing a clean and stable electrical signal, thanks to a design using only high quality components. It thus allows the devices it supplies to deliver their full potential with improved sound quality. In addition, the XP2 has 2 9V DC outputs, particularly useful for powering two devices without multiplying the number of power supplies.
The design of this power supply is based on many years of experience and feedback from the previous range. Thus, the XP2 integrates a custom low noise toroidal transformer perfectly adapted to the Aune X/T product lines. It uses a coil with ultra-pure copper wires ensuring very low losses for high efficiency. The coil is also isolated to limit interference. The transformer is accompanied by Nichicon and WIMA capacitors as well as linear controllers to drastically reduce the ripple.
1.1 | LED Indicator |
2.1 | Power input (IEC connector) |
2.2 | ON/OFF Button |
2.3 | 9V 1A Jack DC Output |
2.4 | 9V 1A Jack DC Output |
Product type | Power supply |
Power supply type | Linear |
Output voltage | 2x 9VDC 1A |
Fuse | 1A |
Dimensions (LxPxH) | 85 x 131 x 60mm |
Case material | Aluminium |
Color | Silver |
Package | 1x Aune XP2 Power supply 1x Main power cable 2x Jack DC to Jack DC cables |
Input | IEC C14 |
Output | Jack DC |
Color | Silver |
Output voltage (V) | 9.0 |
Output current (A) | 1.0 |
Input voltage (V) | N/A |
Power Supply | Linear |
