La différence avec l'alimentation de série est très significative. Le son est plus aéré, plus dynamique...
Un très bon achat !
Linear Power Supply 9VDC 1A / 2x 13.5VAC 0.8A for Aune X1s Pro / X8 / T1s / X5s Black
The XP3 is part of the second generation of XP power supplies adapted to Aune's X/T products. It is a high-end power supply capable of providing a clean and stable electrical signal, thanks to a design using only high quality components. It thus allows the devices it supplies to deliver their full potential with improved sound quality. In addition, the XP2 has 2 9V DC outputs, particularly useful for powering two devices without multiplying the number of power supplies.
The design of this power supply is based on many years of experience and feedback from the previous range. Thus, the XP3 integrates a custom low noise toroidal transformer perfectly adapted to the Aune X/T product lines. It uses a coil with ultra-pure copper wires ensuring very low losses for high efficiency. The coil is also isolated to limit interference. The transformer is accompanied by Nichicon and WIMA capacitors as well as linear controllers to drastically reduce the ripple.
1.1 | LED Indicator |
2.1 | Power input (IEC connector) |
2.2 | ON/OFF Button |
2.3 | 9V 1A Jack DC Output |
2.4 | 2x13.5VAC 0.8A DIN 5 pinsOutput |
Product type | Power supply |
Power supply type | Linear |
Output voltage | 9VDC 1A 2x13.5VAC 0.8A |
Fuse | 1A |
Dimensions (LxPxH) | 85 x 131 x 60mm |
Case material | Aluminium |
Color | Black |
Package | 1x Aune XP2 Power supply 1x Main power cable 1x Jack DC to Jack DC cable 1x DIN 5 pins AC to AC cable |
Input | IEC C14 |
Output | DIN 5 |
Output | Jack DC 5.5/2.1mm |
Color | Black |
Output voltage (V) | 9.0 |
Output voltage (V) | 2x13.5 |
Output current (A) | 1.0 |
Input voltage (V) | N/A |
Power Supply | Linear |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Pascal M.
