BURSON AUDIO FUSION CORE HiFi Power Supply GaN 24V 15A
With the Fusion Core, Burson Audio presents a HiFi power supply rated at 24V and 15A, for a total of 360W, equipped with GaN (gallium nitride) transistors instead of the traditional silicon-based transistors. This new semiconductor technology, a veritable revolution in its field, has a number of advantages for HiFi power supplies.
By buying this product you get 110 loyalty points
Reference : 19881
1 100,00 €tax incl.
916,67 € tax excl.
Burson Audio Fusion Core HiFi Power Supply GaN 24V 15A
Burson Audio Fusion Core : Front view
Firstly, GaN transistors are much more efficient than traditional silicon transistors, limiting the loss of energy during switching and therefore heat generation. The result is a much cooler power supply at equivalent power levels. Furthermore, this increased energy efficiency also reduces the distortion induced in the signal by the power supply.
Furthermore, one of the specific features of GaN transistors is their very high switching speed, with Burson Audio ensuring a switching frequency of the order of 100kHz. This increased speed has several effects: firstly, it eliminates the noise associated with the switching itself in the various circuits, eliminating the background noise. Furthermore, it also means a much faster response time from the power supply, enabling it to adapt quickly to fluctuations in power demand from the devices connected to it.
Product typeHiFi power supply
Input voltage100 - 240V AC
Input connectorIEC C14
Output connector4-pole GX12 snap-fit connector
Output current15A
Output voltage24V
Noise floor<1μV
Dimensions210 x 200 x 75mm
Weight5kg
ColorSilver
Package1x Burson Audio Fusion Core
1x 1.8m power cable
1x 1.5m GX12 to Jack DC 2.5mm cable (Positive in the centre)
InputIEC C14
OutputGX12
ColorSilver
Output voltage (V)24.0
Output current (A)15.0
Input voltage (V)100.0
Input voltage (V)240.0
Power SupplySMPS
With the Fusion Core, Burson Audio presents a HiFi power supply rated at 24V and 15A, for a total of 360W, equipped with GaN (gallium nitride)...
