FERRUM HYPSOS V2 Hybrid HiFi Power Supply Adjustable 5V-30V
Here, Ferrum presents the latest version of its Hypsos power supply. This top-of-the-range power supply combines decoupling and linear power supply technology to offer a hybrid that combines the advantages of both models, namely very low noise and ripple, fast response and high efficiency. Furthermore, in addition to the quality of the power supply, this device is extremely practical, allowing users to experiment in a secure environment to get the best out of their sound system.
By buying this product you get 139 loyalty points
Reference : 19559
1 399,00 €tax incl.
1 165,83 € tax excl.
FERRUM HYPSOS V2 DUAL OUTPUT Hybrid HiFi Power Supply 5V-30V Adjustable
FERRUM HYPSOS : Front view
Here, Ferrum presents the latest version of its Hypsos power supply. This top-of-the-range power supply combines switching mode and linear power supply technology to offer a hybrid that combines the advantages of both models, namely very low noise and ripple, fast response and high efficiency. Furthermore, in addition to the quality of the power supply, this device is extremely practical, allowing users to experiment in a secure environment to get the best out of their sound system.
Ferrum Hypsos : Great ease of use
The Hypsos is compatible with the Apple TV Remote and has a trigger input/output connector, making it possible to automate the switching on of devices in standby mode, even without a dedicated trigger connection. You can also use the predefined settings from the list of supported devices or manually create your own user profile. The Hypsos power supply offers a wide DC output voltage range, from 5V to 30V, with a current of up to 6A.
xxx
Ferrum Hypsos : At the service of your sound system
Sweet Spot Tuning (SST) allows you to experiment with your devices at a different voltage level. You can adjust the level (within the safety range described by the device manufacturer) of the output voltage on the fly, while being sure not to damage your device. In this way, the Hypsos allows your audio system to operate at its maximum potential. Improve sound reproduction by adjusting the voltage level on the fly and using the best combination of 4T Sensing parameters and spectrum diffusion mode.
xxx
Ensure the exact voltage level at the DC input terminal of the powered device. A specially designed cable and feedback function ensure linear voltage at all times. This technique eliminates the adverse effects of cable resistance and significantly improves transient response.
xxx
Ferrum Hypsos : Safety as an imperative
The Hypsos power supply incorporates automatic transformer voltage adjustment (ATVA), an electronic output voltage polarity switch and overvoltage, overcurrent and short-circuit protection. Parameters can be locked to prevent accidental changes.
Product typeHiFi power supply
Input voltage110-240VAC / 50-60Hz
Input connectorIEC C14 With fuse, power button and two-stage EMI filter
Output cables1x Jack DC 5.5/2.5mm 50cm
1x Jack DC 5.5/2.1mm 50cm
Output voltage range5-30V adjustable
Max continuous output current6A
Max continuous output power60 W
Primary winding fuseIEC 5×20 mm, 250 V 3.15 A
Dimensions217 x 206 x 50mm
Weight3.05kg
Package1x Ferrum Hypsos
1x Power cable
1x DC 5.5/2.5mm jack cable
1x DC 5.5/2.1mm jack cable
InputIEC C14
OutputNC
Output voltage (V)30.0
Output voltage (V)5.0
Output current (A)6.0
Input voltage (V)240.0
Input voltage (V)110.0
Power SupplyHybrid
Here, Ferrum presents the latest version of its Hypsos power supply. This top-of-the-range power supply combines decoupling and linear power supply...
