ifi Audio DC iPurifier Filter AC Adapter 5V-24V / 3.5A / 84W
4.0 / 5
Reference : 10940
119,00 €tax incl.
99,17 € tax excl.
TheDC iPurifier from ifi Audioest is a noise suppressor for the vast majority of power adapters (switched) on the market. Indeed the "standard" AC adapters are very noisy and not designed for Audiophile use.
iFi Audio DC Purifier Filtre Adaptateur secteur 5V-24V / 3.5A / 84W
This filter uses new technologyActive Noise Cancelation® , who isinspired by the military's tools, especially the Thales Spectra, which detects and blurs radars.
The DC Purifier will significantly reduce background noise and will uniquely improve your sound reproduction,
from 5V to 24V (up to 3.5A). E fficace ona very wide band, of 1Hz to 5GHz , it develops its best results between 20Hz and 20KHz.
The DC iPurifier is compatible with power supplies from 5 to 24V, and takes up to 3.5A or 84W. Depending on the type of DC outlet, it will work withc the 5.5x2.1mm, or with adapters for the 5.5x2.5mm and 3.5x1.35mm (provided).
Features:/ Strong>
  • Active Noise Cancelation®: AMR Audio Technology
  • Very wide band: 1Hz to 5GHz
  • Compatibilities: Adapters 5 to 24V / 3.5A / 84W
  • Chassis: Aluminum anti RFI
  • Dimensions: 62 x 19 x 18mm
  • Weight: 32g
  • Adapters included: 5.5x2.1mm / 5.5x2.5mm (C) / 3.5x1.35mm
(Included accessories)
Utilisé pour filtrer mon alimentation qui me permet la lecture de fichiers audios sur mini-pc avant d'attaquer ma chaîne hifi. Etrangement fonctionne mieux avec alimentation à découpage qu'avec alimentation linéaire...
This review has been posted for ifi Audio DC iPurifier Filter AC Adapter 5V-24V / 3.5A / 84W
