ifi Audio iPOWER AC-DC Adaptator / Low noise Power supply 9V 2A
Reference : 10187
49,00 €tax incl.
40,83 € tax excl.
This product has been replaced by the new version, the iFi Audio iPOWER MK2 9V.
The iPower is the designated successor of the now-famous Power Adapter Ultra-Low Noise AC / DC Power Adapter, pushing the limits of the power supply and pulling up the entire Ifi Audio range.
Its particularity: Eliminate background noise. (Only 1uV at the Audio Precision 2 test).
By way of comparison, the old AC adapter delivered a noise of 10uV, and a linear Audiophile lambda delivers on average 20 uV ...
The iPOWER can be used anywhere. It is equipped with 4 adapter allowing you to use it everywhere while traveling abroad.
Characteristics :
  • Input voltage: 100 - 240V AC
  • Output Voltage: 9V / 2A
  • Output Connectors: 3.5 / 1.35mm, 4 / 1.7mm, 5.5 / 2.1mm, 5.5 / 2.5mm
  • Noise: 1uV
  • Dimensions: 82x43x40mm
  • Weight: 155g
  • Supplied World Adapters
InputType G Main Plug
InputType I Main Plug
InputType C Main Plug
InputType A Main Plug
OutputJack DC 5.5/2.5mm
OutputJack DC 3.5/1.35mm
OutputJack DC 5.5/2.1mm
OutputJack DC 4.0/1.7m
Output voltage (V)9.0
Output current (A)2.0
Input voltage (V)230.0
Input voltage (V)120.0
Power SupplySMPS
Très bien
L'acquisition de cette alimentation ipower est-elle une bonne chose ? Je crois que la réponse est oui. Les gains sont multiples, en tout cas, dans le contexte de l'utilisation du petit dac usabre d'audiophonics. Ce dac, très bon au demeurant, devient excellent. L'amélioration de la transparence, des petits signaux, du relief et de l'extinction des notes, entre autres, donne une lisibilité et une musicalité accrues.
This review has been posted for ifi Audio iPOWER AC-DC Adaptator / Low noise Power supply 9V 2A
