IFI AUDIO IPURIFIER 3 EMI Filter Female USB-B 3.0 to Male USB-A
In order to drastically reduce the noise of your system, iFi Audio offers you the iPurifier 3. This will reduce distortion effects and finally restore the details of your music.
Reference : 13795
149,00 €tax incl.
124,17 € tax excl.
iFi Audio iPurifier 3
iFi Audio iPurifier 3 Filtre EMI USB-B 3.0 Femelle vers USB-A Mâle
In this version the iPurifier has been greatly improved. It is based on 3 technologies to improve the restitution of your system: REclock, REgenerate, REbalance. It also uses Active Noise Cancellation technology to suppress noise. In addition, iPurifier 3 is compatible with PCM, DSD and DXD formats.
For its iPurifier 3, iFi Audio is based on Active Noise Cancellation technology, adapted from military defense radars. This allows the noise frequencies to be identified and then identical but opposite frequencies to be generated, in order to cancel the noise.
Re-clocking 3-in-1
The iPurifier also integrates other technologies to purify the audio signal. Thus, with REclock the device provides a precise clock and regenerates the signal to eliminate the jitter. REbalance technology allows the DC offset to be removed from the USB signal to rebalance it. This reduces the overall noise on the input signal by 40dB.
Exceptional quality components
To achieve this performance, the iPurifier 3 iFi Audio benefits from high quality components. This includes OS-CON capacitors. These have a low ESR with excellent noise reduction capabilities, ideal frequencies and a long service life. Extremely stable polarized Tantalum capacitors are also integrated, as well as very accurate and reliable MELF resistors.
Anti-EMI Shielding
To block EMI interference that could affect the sound reproduction of your system, the iPurifier 3 uses a copper alloy shield to insulate cables and devices.
Product typeEMI USB Filter
InputFemale USB-B 3.0
OutputMale USB-A
TechnologyActive Noise Cancellation (ANC)
REclock / REbalance / REgenerate
Dimensions64 x 19 x 20mm
Weight33g
ColorWhite
OutputUSB
ColorWhite
Output voltage (V)NC
Output current (A)NC
Input voltage (V)N/A
Power SupplyPower supply filter
2 reviews
ifi ipurifier
quite expensive, but amazing. After a few hours of listening, my meze classics started playing amazingly. I tried different ways of adjusting the USB signal, including battery power, etc., but now with ipurifier it is right sound. Great in conjunction with Audirvana software.The best investment I could have made. I love it.
This review has been posted for IFI AUDIO IPURIFIER 3 EMI Filter Female USB-B 3.0 to Male USB-A
Ben ca marche
Installer pour mon Ifi Audio micro iDSD Black Label, avec un cable Audiophonics Pulsar usb plaqué argent,j'ai entendu un réel changement au niveau du son. Surtout au niveau des aigus qui sont beaucoup plus douce, tout en étant plus détaillés.
Faire attention, les effets ne se font pas entendre tout de suite, il faut un certain rodage. Les premières heures ont été une souffrance pour mes oreilles.
In order to drastically reduce the noise of your system, iFi Audio offers you the iPurifier 3. This will reduce distortion effects and finally...
