Jack DC Supercapacitor Filter 15V
This DC 15V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 6 supercapacitors 5F - 3.0V and an intelligent buffer system with common mode suppression effect. It also incorporates a UTC UZ1085L linear voltage regulator, an STC 8H1K08 microcontroller and a ME85P03 MOSFET transistor.
Reference : 19074
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 22-04-2025.
DC 15V Jack Filter with Supercapacitor to DC Jack
Photo of Jack DC 15V Supercapacitor Filter
This DC 15V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 6 supercapacitors 5F - 3.0V and an intelligent buffer system with common mode suppression effect. It also incorporates a UTC UZ1085L linear voltage regulator, an STC 8H1K08 microcontroller and a ME85P03 MOSFET transistor. Input and output are on DC 5.5/2.1mm jack connectors. LEDs indicate the Jack DC filter loading: 10%, 25%, 50%, 75%, 100%. It is itself powered by 15V 3A via its DC jack input.
Filter operation
When a power supply is connected to the filter input, the 5 LEDs light up cyclically. No voltage is then delivered at the output. The LEDs then light up in the following order: 10% → 25% → 50% → 75% → 100%, as the supercapacitors are charged. To obtain output voltage, it is necessary to reach a charge level of 100%, then press the ON/OFF button. The LED corresponding to the charge level (100%) of the capacitors will then be the only one permanently lit. If the load never reaches 100% with 5 fixed LEDs, and one LED continues to flash, this indicates that your input power supply is not delivering exactly 15V.
Product typeJack DC filter
InputJack DC 5.5/2.1mm
OutputsJack DC 5.5/2.1mm
Dimensions82 x 52mm
ColorArgent
Weight150g
Package1x DC 15V jack filter
1x DC jack cable 5.5/2.1mm to jack 5.5/2.1mm
2x Adapter jack 5.5/2.5mm to jack 5.5/2.1
OutputJack DC 5.5/2.1mm
ColorSilver
Output voltage (V)15.0
Output current (A)NC
Input voltage (V)15.0
Power SupplyPower supply filter
Attention
filtre qui ne convient qu'à une tension strictement de 15v
This review has been posted for DC 15V Jack Filter with Supercapacitor to Jack DC
This DC 15V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 6...
