KECES P6 Ultra Low Noise Regulated Linear Power Supply 5V / 7V / 9V / 12V + 12V / 15V / 19V / 24V 6A
The Keces P6 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful design with a high quality toroidal transformer and a separate ground for each rail.
By buying this product you get 59 loyalty points
Reference : 17468
599,00 €tax incl.
499,17 € tax excl.
Shipping date: 26-12-2024.
Keces P6
Ultra Low Noise Regulated Linear Power Supply 5V/7V/9V/12V + 12V/15V/19V/24V 6A
KECES P6 Ultra Low Noise Regulated Linear Power Supply 5V/ 7V/9V/12V + 12V/15V/19V24V 6A
The Keces P6 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful design with a high quality toroidal transformer and a separate ground for each rail. This internal design provides an ultra-low noise signal and cancels all "buzzing" at 50Hz and maximum load. The power supply also includes protection against exceeding the maximum operating temperature (Over Temperature Protection). All components are placed in a robust and stylish black brushed Aluminium case. The brand logo is stamped into the Aluminium on the power supply cover. A display on the front panel shows the voltage and current delivered by each output.
Dual output
The Keces P6 is particularly interesting also because it offers two adjustable DC outputs. Thus, the first output can be set to 5V, 7V, 9V, or 12V while the second output can be set to 12V, 15V, 19V or 24V. A switch on each output allows you to simply select the desired voltage. On the current side, each output is supplied with 3A. The input voltage is also selectable (230V or 115V AC) via a switch under the device, to adapt to the current supplied by your mains sockets.
KECES P6 Ultra Low Noise Regulated Linear Power Supply 5V/7V/9V/12V + 12V/15V/19V24V 6A
Tecnical characteristics
SpEcifications
Product typeRegulated linear power supply
Input voltage (Switchable)AC 110V-120V 60Hz
AC 220V-240V 50Hz
Output voltageOutput 1 : DC 5V / 7V / 9V /12V
Output  2 : DC 12V / 15V / 19V / 24V
Output connectorJack DC 5.5/2.5mm
Consumption150W (full load)
CaseBrushed Aluminium 4mm
Dimensions220 x 220 x 66mm
Weight3kg
Package1x Keces P6
1x Power cable Schuko / IEC
2x Jack DC 5.5/2.5mm to Jack DC 5.5/2.1mm cable
2x Jack DC 5.5/2.1mm to 5.5/2.5mm cable
Protections
Output voltageOver voltage protectionUnder voltage protectionOverload protectionOver temperature protection
5V5.5V4.5V4.2A80°C
7V7.5V6.5V4.2A80°C
9V9.5V8.5V4.2A80°C
12V12.5V11.5V4.2A80°C
15V15.5V14.5V4.2A80°C
19V19.5V18.5V4.2A80°C
24V24.5V23.5V4.2A80°C
InputIEC C14
OutputJack DC 5.5/2.5mm
Output voltage (V)7.0
Output voltage (V)5.0
Output voltage (V)9.0
Output voltage (V)12.0
Output current (A)4.0
Input voltage (V)230.0
Input voltage (V)120.0
Power SupplyLinear
2 reviews
Trois fois 5*
Voila mon chalenge ; alimenter ces trois éléments:
1 préampli phono MOON 110 en 24V
2 switch CHORD en 5V
3 LIVEBOX ORANGE en 12v
Le gain sur ces trois éléments est au delà de mes espérances et ce sur tour les paramètres sonores.
En plus c'est très rentable comparé a l'achat de trois alim de qualités similaires (SBOOSTER).
Le câble SECTEUR est un RAAM AMADEUS 5 avec prise secteur VIBORG OR (je suis fan de ce câble).
This review has been posted for KECES P6 Ultra Low Noise Regulated Linear Power Supply 5V / 7V / 9V / 12V + 12V / 15V / 19V / 24V 6A
Amazing LPSU
I upgraded my system with a Keces P6 LPSU. It provides power for the Sonos Port and Intel Nuc11 Core i7. Surprisingly, the sound is a bit cleaner now, so it will stay. It provides enough power even on DSD512 upscale.
All my system components are listed:
1. Keces P6 (lpsu)
2. Intel NUC 11 i7 (Roon ROCK)
3. Topping E70 Velvet (Roon to Sonos link, sounds better and more stable than native streaming using Sonos protocol)
4. Sonos Port, Five, Sub
5. Samsung ViewFinity S8 4K HDR monitor + Chromecast Ultra (Roon Display)
The Keces P6 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The...
