KECES P8 Regulated Linear Power Supply
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful design with a high quality toroidal transformer and a separate ground for each rail.
By buying this product you get 79 loyalty points
Reference : 18635
799,00 €tax incl.
665,84 € tax excl.
KECES P8 Ultra Low Noise Regulated Linear Power Supply 9 / 12V + 12 / 15V 4A
Keces P8 Alimentation Linéaire Régulée Ultra Faible Bruit 9 / 12V + 18 / 19V 4A
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply offers a careful design with a high quality toroidal transformer and a separate ground for each rail. This internal design allows to obtain an ultra low noise signal and to cancel all "buzzing" at 50Hz and at maximum load. The power supply also includes protection against exceeding the maximum operating temperature (Over Temperature Protection). All components are placed in a robust and stylish black brushed Aluminium case. The brand logo is stamped into the Aluminium on the power supply cover. A display on the front panel shows the voltage and current delivered by each output.
Keces P8 : Dual output
The Keces P8 is particularly interesting also because it offers two adjustable DC outputs. Thus, the first output can be set to 9V or 12V while the second output can be set to either 12V or 15V. A switch on each output allows you to simply select the desired voltage. The P8 also has a USB connector that delivers 5V. On the current side, each output is supplied with 4A. The input voltage is also selectable (230V or 115V AC) via a switch under the device, to adapt to the current supplied by your mains sockets.
Product typeLinear regulated power supply
Input voltage (switchable)AC 110V-120V 60Hz
AC 220V-240V 50Hz
Output voltageOutput 1 : DC 9V / 12V
Output 2 : DC 12V / 15V
USB-A Output voltage5V
Output connectorsJack DC 5.5/2.5mm
Consumption200W (full load)
CaseBrushed Aluminium 4mm
Dimensions300 x 220 x 66mm
Weight6kg
Package1x Keces P8
1x Power cable Schuko / IEC
2x Jack DC 5.5/2.5mm to Jack DC 5.5/2.1mm cable
Protections
Output voltageOvervoltage protectionUndervoltage protectionOvercurrent protectionTemperature protection
9V9.5V8.5V4.2A80°C
12V12.5V11.5V4.2A80°C
15V15.5V14.5V4.2A80°C
InputIEC C14
OutputJack DC 5.5/2.5mm
Output voltage (V)12.0
Output voltage (V)9.0
Output voltage (V)15.0
Output current (A)4.0
Input voltage (V)120.0
Input voltage (V)230.0
Power SupplyLinear
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The...
