KECES P8 Ultra Low Noise Regulated Linear Power Supply 19 / 20V 8A + USB 5V 1A
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply features a neat design with a high quality toroidal transformer and separate ground.
By buying this product you get 79 loyalty points
Reference : 14671
799,00 €tax incl.
665,83 € tax excl.
Keces P8
Keces P8 Alimentation Linéaire Régulée Ultra Faible Bruit 9 / 12V 8A + 5V 1A
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply features a neat design with a high quality toroidal transformer and separate ground. This internal design provides an ultra-low noise signal and cancels all "hum" at 50Hz and full load. The power supply also incorporates protection if the maximum temperature is exceeded. The power supply also incorporates over temperature protection. All components are housed in a robust and attractive black brushed aluminum case. The brand logo is stamped into the aluminum on the power supply cover. A screen on the front panel displays the voltage and the current delivered.
Adjustable output
If the Keces P8 is so interesting, it is because it has an output with adjustable voltage. A switch allows you to select an output voltage of 19VDC or 20VDC for a current of 8A. The P8 also has a USB connector delivering 5VDC 1A. The input voltage is also selectable (230V or 115V AC) thanks to a switch on the bottom of the unit, to adapt to the current delivered by your mains sockets.
Product typeRegulated linear power supply
Input voltage (switchable)AC 110V-120V 60Hz
AC 220V-240V 50Hz
Output voltage19VDC / 20VDC
Output current8A
USB Output5VDC 1A
Output connectorJack DC 5.5/2.5mm
Consumption200W (full load)
HousingBrushed Aluminum 4mm
Dimensions300 x 220 x 66mm
Weight6kg
Package1x Keces P8
1x Power cable
1x Jack DC 5.5/2.5mm to Jack DC 5.5/2.1mm cable
1x Jack DC 5.5/2.1mm to Jack DC 5.5/2.5mm adapter
Protections
Output voltageOver voltage protectionUnder voltage protectionOver current protectionOver temperature protection
19V19.5V18.5V8.2A80°C
20V20.5V19.5V8.2A80°C
InputIEC C14
OutputJack DC 5.5/2.5mm
Output voltage (V)5.0
Output voltage (V)20.0
Output voltage (V)19.0
Output current (A)8.0
Input voltage (V)230.0
Input voltage (V)120.0
Power SupplyRegulated Linear Power Supply
Stark und edel
Eigentlich habe ich mein Keces Gerät als gebraucht günstiger kaufen können aber seine Ausgangsspannung ist stabiler als bei anderen günstigeren chinesischen Netzteilen. Auf dem Display erscheint auch vieviele Ampére die Last beansprucht, mein HTPC mit Windows10 AsrockVision benötigte nur um die 3A, aber das wusste ich ursprünglich nicht, darum hatte ich diesen starken Netzteil mir gewünscht. Aber nachdem ich Windows stark getweakt habe, vor allem dank MSMGToolkit, habe ich nur noch 1,7 A im Maximalfall. Für mini-PC und Laptop ist absolut notwendig ein Linearnetzteil, ich konnte sofort den Unterschied zum SMPS feststellen, vorher die hohen Töne waren kreischend, überlagert mit SMPS-Schwingungen, jetzt sind sie klarer, ein USB-Isolator allein half nicht genügend.
This review has been posted for KECES P8 Ultra Low Noise Regulated Linear Power Supply 19 / 20V 8A + USB 5V 1A
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The...
