LHY AUDIO BATT-DC Regulated linear power supply on battery 12V 2A
This LHY Audio BATT-DC regulated linear power supply module uses four 21700 batteries with a capacity of 4900mAh (4.9Ah) and an ultra-low-noise LDO LT3042 linear voltage regulation chip with D45H11 PNP transistor.
Reference : 18479
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 16-04-2025.
LHY AUDIO BATT-DC
This LHY Audio BATT-DC regulated linear power supply module uses four 21700 batteries with a capacity of 4900mAh (4.9Ah) and an ultra-low-noise LDO LT3042 linear voltage regulation chip with D45H11 PNP transistor. This linear power supply has a 2-pin GX16 connector output delivering 12V 2A. So you can power your Hi-Fi equipment with an ultra-low-noise signal. The module itself is powered by 16.8V DC on a 5.5/2.1mm DC jack connector. A load protection module completes this input.
Please use the GX16 cable supplied or the Audiophonics references GXDC-21 and GXDC-25 specially designed for LHY Audio power supplies.
LHY AUDIO BATT-DC regulated linear power supply connectivity
1GX16 2-pin 12V DC 2A output
2Voltage adjustment +/5%.
3DC 16.8V power supply input on 5.5/2.1mm jack connector
Product typeBattery-regulated linear power supply
Input voltage16.8V DC
Voltage and output connectors2-pin GX16 connector: 12V DC 2A
Total output current2A
Battery4x 21700 (4900mAh)
Dimensions155 x 100 x 47mm
Weight0.72kg
Package1x Linear regulated battery power supply LHY AUDIO BATT-DC
1x 2-pin GX16 connector cable to DC jack 5.5/2.1mm
1x EU power adapter 100-240V to 16.8V 2A
InputJack DC 5.5/2.1mm
OutputGX16
Output voltage (V)12.0
Output current (A)2.0
Input voltage (V)16.8
Power SupplyRegulated Linear Power Supply
This LHY Audio BATT-DC regulated linear power supply module uses four 21700 batteries with a capacity of 4900mAh (4.9Ah) and an ultra-low-noise LDO...
