LHY AUDIO LPS160VA 12V Linear Regulated Power Supply 12V 9A 160VA
This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio and it will work perfectly with your HiFi equipment operating at 12V.
By buying this product you get 35 loyalty points
Reference : 19653
359,00 €tax incl.
299,17 € tax excl.
Shipping date: 16-04-2025.
LHY Audio LPS160VA 12V Linear Regulated Low Noise Power Supply 230V to 12V 9A 160VA
LHY AUDIO LPS160VA : Vue de face
This power supply includes a 160VA toroidal transformer resulting from cooperation between Noratel and Talema, coupled with an OP177 OPA to stabilise and control the voltage with furthermore precision. An RFI filter is also included to eliminate interference created by AC current. Furthermore, Rubycon capacitors stabilise the current reliably, providing a clean, continuous signal with noise levels of no more than 29µV. Finally, the power supply benefits from an aluminium alloy case for efficient heat dissipation and two GX16 aviation outputs.
Please use the GX16 cable supplied. If you use another cable, make sure that the polarity of the two pins is correct.
Cabling diagram
Product typeRegulated linear power supply
Input voltage230V
Output Voltage / current12V 9A
InputIEC
Outputs2x GX16 aviation connectors
Case materialAluminium alloy
Dimensions140 x 260 x 90mm
Weight4.5kg
Package1x LHY Audio LPS160VA
1x GX16 to DC 5.5/2.1mm male jack cable
1x Power supply cable
InputIEC C14
OutputGX16
Output voltage (V)12.0
Output current (A)9.0
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
ALIMENTATION LPS160VA 12V
Commande passée le 24 Février, enfin reçue le 20 Mars.
1 Mois, c'est franchement exagéré, surtout que l'argent est encaissé à la commande. Il pourrait faire un geste commercial sur une prochaine commande.
Heureusement pour Audiophonics, les produits sont de qualités et à part une personne qui m'a fait comprendre que si je n'étais pas content je pouvais annuler ma commande et l'acheter ailleurs, les autres personnes avec qui j'ai échangé techniquement ont toutes été sympathiques et professionnelles.
Dominique Guion.
This review has been posted for LHY AUDIO LPS160VA 12V Linear Regulated Low Noise Power Supply 230V to 12V 9A 160VA
This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY...
