LHY AUDIO LPS160VA 19V Linear Regulated Power Supply 19V 7A 160VA
This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio and it will work perfectly with your HiFi equipment operating at 19V.
By buying this product you get 35 loyalty points
Reference : 19656
359,00 €tax incl.
299,17 € tax excl.
Shipping date: 16-04-2025.
LHY Audio LPS160VA 19V Linear Regulated Low Noise Power Supply 230V to 19V 7A 160VA
LHY AUDIO LPS160VA : Vue de face
This power supply includes a 160VA toroidal transformer resulting from cooperation between Noratel and Talema, coupled with an OP177 OPA to stabilise and control the voltage with furthermore precision. An RFI filter is also included to eliminate interference created by AC current. Furthermore, Rubycon capacitors stabilise the current reliably, providing a clean, continuous signal with noise levels of no more than 29µV. Finally, the power supply benefits from an aluminium alloy case for efficient heat dissipation and two GX16 aviation outputs.
Please use the GX16 cable supplied. If you use another cable, make sure that the polarity of the two pins is correct.
Product typeRegulated linear power supply
Input voltage230V
Output Voltage / current19V 7A
InputIEC
Outputs2x GX16 aviation connectors
Case materialAluminium alloy
Dimensions140 x 260 x 90mm
Weight4.5kg
Package1x LHY AUDIO LPS160VA
1x GX16 to DC 5.5/2.1mm male jack cable
1x Power supply cable
InputIEC C14
OutputGX16
Output voltage (V)19.0
Output current (A)7.0
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
2 reviews
indispensable
Installation sur un Mini PC I9, elle a remplacé l'alimentation d'origine haut la main et contribue au silence électrique de la sortie USB et réseau du logiciel HQPlayer.
Quelque peu imposante tout de même...
This review has been posted for LHY AUDIO LPS160VA 19V Linear Regulated Low Noise Power Supply 230V to 19V 7A 160VA
Excellent for „ASUS NUC 14 Pro“ with Intel Core U7 155H CPU
EXPERIENCE WITH MY OLD NUC & LPSU:
For my previous NUC I have already used a LPSU delivering 19V/5.25A (AUDIOPHONICS LPSU100 Stabilized Power supply 19V 5.25A 100W NAS / Intel Nuc). The NUC was mainly used as Roon-Server based on Windows (and some other tasks), whereas importantly my DAC was not directly plugged into the NUC! But as a believer in LPSUs in general, I blindly believed in its superior sound-quality compared to the NUC’s stock switching-PSU - but I have never tried any A/B-testing ever since.
EXPERIENCE WITH MY NEW NUC14 & LPSU:
With buying my new NUC (ASUS NUC 14 Pro“ with Intel Core U7 155H CPU), I have instantly ordered the new LPSU delivering 19V/7A. As the LPSU was out of stock, I had to wait a few weeks to finally arrive. In the meantime, I took the chance carefully listening to music using the NUC’s stock-PSU. The sound-quality felt surprisingly good – and therefore I was very excited about the potential of new LPSU.
After arrival in winter the new LPSU was cold and for the first couple of hours it did not seem to leverage any sound-quality. But to my ears the sound-quality continuously improved – and after about 10-20 hours I felt much more pleased (please excuse me not trying to describe any positive effects).
QUESTION & CONCLUSION
Does it make any sense empowering a NUC with a comparably expensive LPSU? (especially, if the NUC is streaming music via network without a DAC being attached directly)
I would say that it depends:
- Yes, if the sound-quality is already rather pleasing using the NUC’s stock-PSU.
- No, if the sound-quality is not already pleasing using the NUC’s stock-PSU, as the sound-signature will not change dramatically. In this case I would rather spend my money on other parts of my equipment prior to buying a LPSU for a NUC. Even though a LPSU does improve a NUCs sound-quality, possibly a DAC, network-switch, USB- or network-card may profit even more.
In my case the sound-quality did seem to have improved and additionally I enjoy the looks and feel of this heavily built LPSU. As I will continue empowering my NUCs with LPSUs in future, I recommend this one without any doubt!
This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY...
