LHY AUDIO LPS160VA 24V Linear Regulated Power Supply 24V 5A 160VA
This LHY AUDIO LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio and it will work perfectly with your HiFi equipment operating at 24V.
By buying this product you get 35 loyalty points
Reference : 19657
359,00 €tax incl.
299,17 € tax excl.
Shipping date: 16-04-2025.
LHY Audio LPS160VA 24V Linear Regulated Low Noise Power Supply 230V to 19V 7A 160VA
LHY AUDIO LPS160VA : Vue de face
This LHY Audio LPS160VA regulated linear power supply provides great stability for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio and it will work perfectly with your HiFi equipment operating at 24V.
This power supply includes a 160VA toroidal transformer resulting from cooperation between Noratel and Talema, coupled with an OP177 OPA to stabilise and control the voltage with furthermore precision. An RFI filter is also included to eliminate interference created by AC current. Furthermore, Rubycon capacitors stabilise the current reliably, providing a clean, continuous signal with oise levels of no more than 29µV. Finally, the power supply benefits from an aluminium alloy case for efficient heat dissipation and two GX16 aviation outputs.
Please use the GX16 cable supplied. If you use another cable, make sure that the polarity of the two pins is correct.
Product typeRegulated linear power supply
Input voltage230V
Output Voltage / current24V 5A
InputIEC
Outputs2x GX16 aviation connectors
Case materialAluminium alloy
Dimensions140 x 260 x 90mm
Weight4.5kg
Package1x LHY Audio LPS160VA
1x Plane GX16 to DC 5.5/2.1mm male jack cable
1x Power supply cable
InputIEC C14
OutputGX16
Output voltage (V)24.0
Output current (A)5.0
Input voltage (V)230.0
Power SupplyRegulated Linear Power Supply
LHY AUDIO LPS160VA 24V Linear Regulated Low Noise Power Supply 230V to 24V 5A 160VA
This LHY AUDIO LPS160VA regulated linear power supply provides great stability for any high-quality audiophile...
