LHY AUDIO LPS25VA Linear Regulated Power Supply 12V 1A
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 12V 2A 25VA
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 12V.
Reference : 19036
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 17-09-2024.
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 12V 1A 25VA
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 12V 2A 25VA : Front view
This power supply includes a Talema transformer coupled with an AOP 177 for even greater voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 200uV when used to its full capacity.
The power supply features an aluminum alloy case for efficient heat dissipation and two DC 5.5/2.1mm jack output. Finally, you can adjust the output voltage on the back of the device by ±0.5V if required.
Input voltage220-240V
Output Voltage / current12V 2A Max
12V 1A Continuous
Outputs2x Jack DC 5.5/2.1mm
InputIEC
Case materialAluminium alloy
Dimensions110 x 155 x 63mm
Weight1.114kg
Package1x LHY AUDIO LPS25VA
1x DC 5.5/2.1mm male/male jack cable 80cm
1x power supply cable
InputIEC C14
OutputJack DC 5.5/2.1mm
Output voltage (V)12.0
Output current (A)1.0
Input voltage (V)220.0
Power SupplyRegulated Linear Power Supply
2 reviews
La classe 5 étroite
produit super top avec des prise secteur furutech NCF rhodium
rapidité qualité l'image o rdv sans hésitation un vrai régal Netflix je note 5 étoile merci !
This review has been posted for LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply 220V to 12V 1A 25VA
super génial
Produit top la classe qualité sonore l'image incroyable vue rapport qualité prix rien à dire compatible sfr zeop orange
netflix 5 étoile bon matos 2024 merci
Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are...
